<<  1    2  >>
Author: Subject: capri wheels size?
eccsmk
posted on 3/6/08 at 06:31 PM Reply With Quote
capri wheels size?
ive got some 13" capri 4 spoke wheels coming but i haven't a clue how wide they are
can anyone help me out ?
thanks
[Edited on 3/6/08 by eccsmk]
[Edited on 5/6/08 by eccsmk]
grub
posted on 3/6/08 at 06:36 PM Reply With Quote
id have a good guess at 6j
aerosam
posted on 3/6/08 at 06:45 PM Reply With Quote
5.5j, you can stick 205 wide tyres on them no probs.
Trust me, I owned a capri for years, sold it so I could start building a locost. Oh man! what did I go and do that for????
posted on 3/6/08 at 07:26 PM Reply With Quote
Yes 5.5"
Mark Allanson
posted on 3/6/08 at 07:38 PM Reply With Quote
No they are 6" ET19
grub
posted on 3/6/08 at 07:41 PM Reply With Quote
come on lets have a fiver on it
posted on 3/6/08 at 07:50 PM Reply With Quote
RS2000 4 spoke alloys are generally the 6" ones --- easy way to tell is they use different wheel nuts
For for best handling choose tyres at the narrow end of the fittment range for a given rim width, fit tyres at the wide end and the handling gets wobbly because the tyre rolls about on the rim.
AndyGT
posted on 3/6/08 at 08:01 PM Reply With Quote
Rs2K wheel are 6J and the capri ones are 5.5J
Wheel nuts are exactly the same.
Trust me I have a set in the garage 10 metres from where I am sat!
Good wheels and are a small fortune for the RS2K ones!!!
nothing is impossible
everything is possible
Blue Fox
posted on 3/6/08 at 08:21 PM Reply With Quote
I recently bought a set of 4 spoke alloys and they are definatly 6J I only paid £25, thought they were capri ones, how can I tell if they are the expensive type and how expensive is expensive? - if they are may sell them and get some cheaper capri ones and make a few quid for funding some other bits!
mr henderson
posted on 3/6/08 at 08:48 PM Reply With Quote
Original ford wheels would have been 5.5J
I made a Dutton Phaeton out of a Capri 3Litre (Mk1 facelift)
That was a long time ago
John
[Edited on 3/6/08 by mr henderson]
Shamrock GS
posted on 3/6/08 at 09:25 PM Reply With Quote
5.5J - just went out for a look.
I broke up a 2l capri for my locost - gives a slightly wider rear wheel base as I think the capri was wider than an escort.
Wonder what the capri would have been worth if I had kept it?
Gary
Sun Tzu, The Art of War
Thinking about it
posted on 3/6/08 at 09:29 PM Reply With Quote
6 inch for me.
I have a set of 6" four spoke. The date on the casting is 1986. This would have made them from a Capri Laser as the RS2000 was out of production by then.
Was it the original RS wheels that took the bolts with a flat seat? I think some of those came even wider.
[Edited on 3/6/08 by Thinking about it]
eccsmk
thank you folks
what ill do when they arrive is take a pic and measure the width
Thinking about it
posted on 3/6/08 at 09:33 PM Reply With Quote
Could it be 5.5 on 1.6 and 6 on the 2.0 Laser?
Then everyone is right.
24vseven
posted on 4/6/08 at 12:00 AM Reply With Quote
right i buy and sell these sort of bits all day long so here you go
mk1 escort 4 spokes are 5.5j
mk2 escort are 6j
both have thinner casting around the nut area so are easy to spot
all capri laser 4 spokes are 6j and have thicker casting around the nut area and have tapered nut seats
mk1 fiesta supersport are 5.5j but are a different offset and the "spokes" are almost flush with the rim edge
capri and escort "x-pack" wheels are uber rare and are 7.5j
many people try to pass capri wheels off as rs ones but they are not so be careful
i also belive the jps capri had 5.5j but these again are just mk rs wheels with different center caps
mr henderson
posted on 4/6/08 at 06:49 AM Reply With Quote
but, of course, not all Capris are Capri Lasers
posted on 4/6/08 at 06:59 AM Reply With Quote
When measuring wheels measure from inside the edges of the rim where the tyre bead seals --- it makes almost exactly 0.5" difference.
Capris used 3 different rear axle widths --- 4" difference between a Mk1 1300 and the last Mk3 2.8
24vseven
posted on 4/6/08 at 07:47 AM Reply With Quote
of corse i ment that type ie laser and s
ghias had a different type of wheel totaly
Mark Allanson
posted on 4/6/08 at 05:03 PM Reply With Quote
Mine came odd a 2.0 S Capri (see my avatar) and are clearly embossed with 6J 13
posted on 4/6/08 at 06:10 PM Reply With Quote
I have a set of Capri Laser wheels as well, definitely 6J.
eccsmk
posted on 5/6/08 at 03:50 PM Reply With Quote
well i got these
they will do me for trackdays
width
24vseven
posted on 5/6/08 at 04:45 PM Reply With Quote
yes there fine i think there capri laser wheels we run them on the rally car for forest events
eccsmk
posted on 5/6/08 at 04:56 PM Reply With Quote
anyone like to help me with tyre size
Mark Allanson
posted on 5/6/08 at 06:14 PM Reply With Quote
14" tyres are easy to fit, but a bit unstable at speed
Seriously, I have 185 60 13 H and am really pleased with them, 70's are also popular
eccsmk
posted on 5/6/08 at 07:01 PM Reply With Quote
change of plan now as these will not fit over my rear calipers doh
<<  1    2  >>
