iiyama
| posted on 4/6/08 at 07:03 PM |
seat mounting
Will SVA man look for high tensile bolts for seat mounting?
If its broke, fix it. If it aint broke, take it apart and find out how it works!
jacko
| posted on 4/6/08 at 07:27 PM |
Yes they do some times he did on mine best to use the right bolts
Jacko
twybrow
| posted on 4/6/08 at 07:35 PM |
The SVA manual says "attached to the vehicle using 8mm (grade 8.8 or better) fasteners no more than approx 100mm apart". That is in the
seat/runners section.
iiyama
| posted on 4/6/08 at 08:59 PM |
100mm? I was only looking at two bolts per runner!
Interestingly enough I bought some Caterham runners, (dont ask!), these only have provision for two bolts per runner...............
richard
| posted on 4/6/08 at 09:18 PM |
Mine two months ago was fine with the 4 bolts ( two per side of seat ) that came with the roadster 7 seats. The are cap headed bolts, not sure of they
were marked or not.
twybrow
| posted on 4/6/08 at 09:36 PM |
The 100mm spacing is for 'low profile' runners. 'Heavy duty' runners need bolts at no more than 250mm.
iiyama
| posted on 5/6/08 at 07:02 AM |
Still seems a lot. Ill go with plan A and see what happens I think.
Thanks guys
wicket
| posted on 5/6/08 at 03:22 PM |
The 100mm & 250mm fixings spacing is that for seat tracking, see section 5 annex 1.
