Author: Subject: Had enough now...MK Electrics...................
LBMEFM
posted on 4/6/08 at 08:43 PM Reply With Quote
I bought a MK wiring loom for my Indy - Fireblade, could not make head or tail of it, so sold it. Then extended the Fireblade loom using a trailer multi-core cable to the rear lights. So far so good, had problems connecting up the ignition circuit after spending sometime tracing the faults still no spark. To have a break I decided to connect the fuel gauge that previously worked to find along with the headlights they did not now work, a loose crimp terminal. I am getting really pi@@ed off now. Question;
1. Do I strip it out again and buy a proper loom, I hear Vicky Green one's are good?
2. Keep working on the current one and hope it stays together?
3. Beg and pay one of you guys to help me overcome my problems (any volunteers) living near Dover, Kent.
4. Sell the car and stay pissed in the pub until the money has gone?
Please help
Barry
[Edited on 4/6/08 by LBMEFM]
RichardK
posted on 4/6/08 at 09:20 PM Reply With Quote
I wouldn't say Vicky Green ones are that good, took quite a bit of fiddling to get mine right and I consider myself fairly handy with the sparky stuff. I've heard good things about Premiere Wirings loom, maybe wortha look but not sure about the bike bit.
Rich
Gallery updated 11/01/2011
omega0684
posted on 4/6/08 at 09:26 PM Reply With Quote
hi barry
dont be so negative! when i started the wiring on my car i absolutely crapped myself cuz i new nothing about electrics what so ever! i had help from stevec (BIG THANKS THERE STEVE IF YOU ARE READING THIS THREAD) on the forum but he does only live 3 miles away.
the basic idea that helped me get through it all was to make things as simple as possible! i effectively created 4 looms instead of 1.
1.front of car - lights, indicators and the switchs etc,
2.engine bay
3. the dash
4. the back of the car - rear lights, indicators etc
when i found myself becoming frustrated at not being able to do something, then i just left my tools exactly where they were and went back to it the following day. this gives you time to think about what you are doing instead of sitting next to your car on the verge of a breakdown cuz you cant get anything done!
if your loom diagram is a bag of S**T, i assure you the vicki green one i was supplied with was, then make a few drawings of your own on a seperate piece of paper, again allows you to draw individual circuits and they are a lot clearer.
hope this helps,
hang in there buddy! you get through it, dont throw in the towel just yet.
All the best
Alex
Kev99
posted on 4/6/08 at 09:42 PM Reply With Quote
I Hope The Information Helps
But do it as omega0684 says do one small bit at a time and if u get stuck walk away and go back the next day
Kev..............
[Edited on 4-6-08 by Kev99]
LBMEFM
posted on 4/6/08 at 09:47 PM Reply With Quote
Thanks guys, particulary kev99, I will get this car going I will, I will, I will, I will, I will, I will, I will............................... Barry
RK
posted on 5/6/08 at 01:17 AM Reply With Quote
The way I see it, so many people HAVE been able to do it, that if some basic principles are followed, it's possible.
This is coming from someone who goes ballistic at every small job gone wrong who hasn't started electrics yet (beyond getting the engine wired). In other words, I don't know what I'm talking about but I totally understand frustration!
jabbahutt
posted on 5/6/08 at 06:43 AM Reply With Quote
stick with it, I've had problems with nearly every step of the wiring, just check the number of posts
Everyone here has been really helpful and everytime you manage to get even the smallest bit of electrickery to work it spurs you on to do a little bit more.
AS said above if it's not working, walk away and think it over. You normally have a blast of inspiration when you least expect it.
Hang in there
Nigel
posted on 5/6/08 at 07:59 AM Reply With Quote
I found the VG loom itself OK, but the wiring diagram could have been better.
I ended up redrawing the wiring diagram to match my own set-up of parts etc - this makes it much easier to follow and come back to when you want to make changes in the future.
ChrisS
posted on 5/6/08 at 08:10 AM Reply With Quote
Please help
Barry
Barry
I live in Herne Bay, so im not that far from you, and i think you may have already been in contact with a mate of mine also building called Roger. Im pretty busy at the moment, but im sure between us we can help. I did my own loom by mating the sierra column to the Yamaha loom and extending that for lights etc. Its not as bad as you think. Ill have a chat with Rog and maybe we can pop down and take a look at some point.
All the best
Chris
