Author: Subject: reverse box
jambo
posted on 8/6/08 at 11:35 PM Reply With Quote
reverse box
can someone please tell me which way round the reverse box goes ie.where should the oil cap be positioned or whatever.
havent got the password for the online manual yet.
bassett
posted on 9/6/08 at 09:10 AM Reply With Quote
From looking at the build manual picture it goes with the cap at the back next to the passenger.
marc n
posted on 9/6/08 at 09:21 AM Reply With Quote
rear end is reverse light
switch to rear.
please email rather than u2u
chrismnrltd@btinternet.com
jambo
posted on 9/6/08 at 05:32 PM Reply With Quote
from that i cant tell,so in the picture is it right or wrong.
marc n
posted on 9/6/08 at 07:55 PM Reply With Quote
yep thats correct
cheers
marc
bassett
posted on 9/6/08 at 09:26 PM Reply With Quote
Sorry for my wrong input it was all i could tell from the picture i had, always a bit confusing which way round stuff looks in the manual
Dillinger1977
posted on 10/6/08 at 12:17 PM Reply With Quote
just thinking, would it matter if it was the wrong way around?
-Rog
Johneturbo
posted on 10/6/08 at 03:57 PM Reply With Quote
Hmm i've got mine the other way, so when the lever is forward both input and output of the quaife turn the same way, ie forward
GeorgeM
posted on 10/6/08 at 05:18 PM Reply With Quote
Had a long conversation with quaiffe
about this at the autosport show in January.
One end of the box (switch end) has a double
bearing, so is stronger. This should be
connected to the longest prop, in our case the
rear. However, they say, and have confirmed
to me, that the box is strong enough to be
mounted either way round!
Quaiffe have a tech support number.....
GeorgeM
Johneturbo
posted on 10/6/08 at 05:38 PM Reply With Quote
GeorgeM
Very interesting, so having it the way they sugest would mean reverse would be lever forward.
one thing make sure you have a breather, or it's oil everywhere! i made one up with with a plumbing fixing from BQ. as per an old post by Dillinger1977
GeorgeM
posted on 10/6/08 at 07:36 PM Reply With Quote
yes, it means the lever forward to go back,
and back to go forward.
I took my box out after talking to them but didn't
like the lever that far back. With the lever
at the front it's completely out of the way and has
to be pulled back to go back. It's only just possible
to reach it without releasing the belts.
When I turned it round, I felt the lever could
easily be knocked forward, It was almost where a
gear lever would be. Not something I fancy
happening at speed; at best a neutral, at worst......
I did look at moving the lever to the other end
of the box, but although the case is drilled the
shaft can not be turned round.
Given the choices, I'm leaving mine with the lever at the front
GeorgeM
jambo
posted on 10/6/08 at 09:41 PM Reply With Quote
where does the breather go?
also,does it come filled with oil
and the nut heads have small holes in them,is this for retaining wire or something.
GeorgeM
posted on 10/6/08 at 09:59 PM Reply With Quote
breather replaces orange cap on top
oil goes in big nut on side below breather
fill to bottom of hole.
make sure its the right oil though.
GeorgeM
