Author: Subject: Clarke 135TE regulator
Jezzer99
posted on 10/6/08 at 12:48 PM Reply With Quote
Hi - can't find this in the archives... which regulator do I need to convert a Clarke 135TE to use "normal" gas bottles?
Cheers.
posted on 10/6/08 at 01:09 PM Reply With Quote
You need something like this so you can use a proper regulator and just connect to the larger hose with the existing pipe.
mad-butcher
posted on 10/6/08 at 07:59 PM Reply With Quote
go to mig welding forum contact a guy called weldequip you need a reg with flow meter and piping to go from reg to that poxy little plastic pipe
Tony
