<<  6    7    8    9    10    11  >>
New Topic New Reply
Author: Subject: Electrolysis. See the light!
posted on 27/2/07 at 09:31 PM Reply With Quote
Originally posted by Guinness
How does this work again.
Can't be arsed to trawl through the entire thread.
Mike
Just read the first post Mike. Says it all really.
Phil
iank
posted on 27/2/07 at 09:34 PM Reply With Quote
Just make extra sure not to use stainless electrodes. Nasty stuff generated.
Anonymous
roadrunner
posted on 31/3/07 at 09:06 PM Reply With Quote
well that took along time to read.
Blakey_boy
posted on 21/5/07 at 11:03 AM Reply With Quote
Got to admit that this thread may be long but a very good tip indeed.
It has saved me hours on derusting and cleaning with the usual brushes and other items and made the process a bit cleaner
Excellent thread and tip
ghuncha
posted on 11/9/07 at 12:36 PM Reply With Quote
great thread... will try it soon.. i have a rusted fkywheel(samll amoutn of rust) i jsut wana ask that will it be ok to derust the flywheel via this method, im mean will there be any structural problems to the flywheel?
another_dom
posted on 21/9/07 at 04:06 PM Reply With Quote
I've just cleaned two cast iron brake discs using this method. Absolutely brilliant and no damage to machined faces. Flywheel won't be a problem (assuming it isn't dual-mass etc).
Dom.
Liam
posted on 21/9/07 at 07:30 PM Reply With Quote
I personally wouldn't want to electrolysis a production flywheel. It's such a critical and highly stressed part, so the possibility of hydrogen embrittlement weakening an already relatively brittle cast part would rule out electrolysis for me. You say it's not much rust, and it's not a complex shape, so 10 minutes with the wire brush would probably be a better idea.
Liam
VinceGledhill
posted on 3/10/07 at 03:41 PM Reply With Quote
Just a thought.
Does anyone know what chemicals to use to chrome plate something?
Regards
Vince Gledhill
Time Served Auto Electrician
Lucas Leeds 1979-1983
Angel Acevedo
posted on 6/10/07 at 03:59 PM Reply With Quote
IMHO i`d leave chroming to the pros as it is nasty stuff...
thunderace
posted on 7/11/07 at 06:05 PM Reply With Quote
http://www.bhi.co.uk/hints/rust.htm
John P
posted on 17/11/07 at 10:53 AM Reply With Quote
Electrolysis - Tried it at last
Finally decided I'd better get on and refurb the front uprights and callipers.
Not sure why 'd put it off before but finally decided to give electrolysis a go.
The electrodes were just off cuts from the chassis which I wired to a piece of copper tube resting on a bucket. The solution was washing soda at a concentration of approx 1 tablespoon / 5 litres of water.
[img]http:// [/img]
Battery charger didn't show much current but overnight the process worked very well although I did have to wire brush it fairly thoroughly afterwards.
[img]http:// [/img]
Anyway, if youre thinking about electrolysis then give it a go. just wish I knew about the process when I was restoring my Austin 7!
John.
MikeCapon
posted on 18/1/08 at 04:22 PM Reply With Quote
Hydrogen embrittlement
When plating components we have had some problems with hydrogen embrittlement. The "de-embrittlement " process is 250°C for 90mins. Having siad that it's only going to be a problem for highly stressed items. for example caliper bolts, road springs etc. The de-embrittlement should be done straight after the electrolysis.
[Edited on 18/1/08 by MikeCapon]
Angel Acevedo
posted on 20/1/08 at 01:08 AM Reply With Quote
Electrolysis Vs. Molasses
I have done both, and I`ll go for the molasses method.
I don`t think it has any of the problems associated with electrolysis.
Maybe a little bit slower.
James
posted on 31/1/08 at 07:33 PM Reply With Quote
For goodness sake!
That links suggests using a stainless steel electrode.... which as has been discussed in this LB thread gives off a very nasty poisonous gas!
Be warned!
Angel Acevedo
posted on 1/2/08 at 04:12 AM Reply With Quote
The poison is in the liquid, Chromium salts dissolved.
hellbent345
posted on 8/6/08 at 07:56 PM Reply With Quote
the link at the start doesnt work now anyone got any other sites with good info on leccytrollysis?
Jesus-Ninja
posted on 17/7/08 at 05:29 PM Reply With Quote
Found this: http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
Suspension geometry tool here >>> http://www.locostbuilders.co.uk/viewthread.php?tid=81376
Jeffers_S13
posted on 30/7/08 at 08:45 PM Reply With Quote
Has anyone done a block yet ??
Jesus-Ninja
posted on 2/8/08 at 12:30 AM Reply With Quote
Eh up, Jeffers!
What about an S13, they're usually pretty rusty.....
reyres
posted on 10/9/08 at 02:34 PM Reply With Quote
Electrolysis - Link
[Edited on 10/9/08 by reyres]
mr henderson
posted on 10/9/08 at 05:12 PM Reply With Quote
tomprescott
posted on 17/10/08 at 10:56 AM Reply With Quote
That looks very handy but the link doesn't work, does anyone have an active link or could somebody tell me what I need to do please? I have a whole sierra to strip of parts and de-rustiy ready for my locost.
Z20let Corsa
posted on 5/12/08 at 01:16 PM Reply With Quote
same. anyone got a link that works??
locost +4 v8 in progress.
Irony
posted on 11/8/09 at 03:11 PM Reply With Quote
Hydrogen Embrittlement
While this is a awesome thread and the process seems to be almost magical I have one worry.
I have tried to make sense of Hydrogen Embrittlement and also this de-brittlement process.
Is there anyone out there who understands and has researched this part of this process. I would hate to be doing 80mph and hit a bump and a suspension arm snaps only to be told 'cause of accident - hydrogen embrittlement' ' no insurance payout' and also I am dead.
Is this a worry or should I just slap myself with a fish and get out my battery charger????
posted on 25/8/09 at 12:43 PM Reply With Quote
Irony, as your name suggests you may be worried.
Have a read of THIS, it may put your mind at rest and let you get on with it
<<  6    7    8    9    10    11  >>
New Topic New Reply
