locobri
posted on 10/7/08 at 09:56 AM |
Type9 gearbox to 1300 crossflow
I have a 1300 crossflow and a type 9 gearbox. what changes do I need to make to get them to work. I have got hold of a correct clutch plate for the
gearbox but was unable to engage gear. It has been sugested that I change the flywheel as well. Is this nessesary?
Mr Whippy
posted on 10/7/08 at 10:13 AM |
when you press the clutch does it actually disengage the drive? i.e put it in gear (engine off) push the pedal down or leaver the arm over and try to
rotate the propshaft. if it does turn without trying to turn the engine then the clutch works. if not then you may have to find another size of thrust
bearing or maybe another lever arm (or modify it). you just need to do a bit of investigation to see what’s going on.
Another thought is maybe your clutch pedal is simply to short to move the lever arm enough to disengage, perhaps get a crowbar and push the arm as far
as it will go them see if that disengages the clutch.
If you can’t reach the prop shaft, put one rear wheel on the ground and jack the other up then turn that wheel.
[Edited on 10/7/08 by Mr Whippy]
locobri
posted on 10/7/08 at 10:20 AM |
With the engine switched off I can select any gear by pressing the clutch. If the engine is turned on whist in gear (clutch pedal pressed in the car
will start and creep froward slightly. With the engine started, I can't get any forward gear but can just crunch reverse.
82 Locost
posted on 10/7/08 at 10:38 AM |
It sounds to me like the clutch is just dragging and you should be able to adjust that out. Are you getting full lever travel when you press the
clutch pedal, or could it move further?
I don't think the flywheel needs changing.
Reverse crunching happens on my type 9, I just select 2nd before reverse and it's better then.
[Edited on 10/7/08 by 82 Locost]
BillHoll
posted on 10/7/08 at 10:43 AM |
You should not have to modify anything else. The problem is related to clutch drag this could be for a few reasons.
1. The clutch plate is in the wrong way round.
2. The clutch plate is sticking on the gearbox input shaft splines.
3. The spigot bearing is too tight i.e. wrong size.
4. The gearbox input shaft is too long, I believe some of the type 9's had a longer input shaft.
5. Or as Mr Whippy says the lever is not trvelling far enough.
Unfortunately to rectify it means engine out.
Hope this helps
posted on 10/7/08 at 11:19 AM |
There can sometimes be an issue with the type of release bearing:
If your clutch cover has flat fingers then you need the bearing with a curved face.
If the cover has raised fingers then you need a flat-face bearing.
Pictures courtesy of Burtons - who can advise on which bearing goes with which cover (these aren't quite the right ones)
locobri
posted on 11/7/08 at 10:30 AM |
Many thanks to all that took time to make thier suggestions. I will work through them and let you know which one worked.
locobri
posted on 13/7/08 at 09:17 PM |
thanks again for all suggestions posted. I've worked through them and at last one work. it was all down the the clutch cover plate that was
at fault. a friend had a spare one which I tried and it worked. Big relief and thanks again.
