<<  1    2  >>
Author: Subject: Noisy Zetec Blacktop Again
whitestu
posted on 11/7/08 at 05:46 PM Reply With Quote
Following on from my previous post, the Zetec is in and running well, but I still have a top end noise.
I'm going to be putting 2.0 cams in soon and want to try to diagnose the cause of the noise when I fit them. There is no apparent wear on the existing cams and the valve clearances are fine.
However to me the noise sounds like a worn cam, except for it comes and goes a bit when cold and goes completely when warm.
The engine runs fine and has been driven hard over the past couple of weeks with no problems.
Any suggestions?
Link to video
Stu
big_wasa
posted on 11/7/08 at 06:17 PM Reply With Quote
I can not think how that is cam train noise ?
whitestu
posted on 11/7/08 at 06:21 PM Reply With Quote
It definitely sounds like its from the top end though. What else could it be?
Stu
Bigheppy
posted on 11/7/08 at 06:44 PM Reply With Quote
Why don't you use the locost stethoscope, put a screwdriver to your ear then touch it on the cam cover , move it along to see if the sound is louder in a particular position. Then try to touch other parts of the engine. It wont tell you what is causing the problem, but this would give you an idea where the noise is coming from.
r1_pete
posted on 11/7/08 at 07:12 PM Reply With Quote
Sounds like a small end bearing gone....
Ketchup
posted on 11/7/08 at 07:53 PM Reply With Quote
Sorry to agree with the above, but it does sound like an end knock to me too
jacko
posted on 11/7/08 at 08:06 PM Reply With Quote
Valves tapping piston tops ? is the cam timing right ? or as above small end
austin man
posted on 11/7/08 at 08:36 PM Reply With Quote
disconnect the water pump belt run the engine this will rule out water pums altenator etc, had a simmilar problem with the silvertop, problem was Knackered alternator bearing
whitestu
posted on 11/7/08 at 09:09 PM Reply With Quote
I'd considered a small end bearing. I'm surprised that it goes away when warm though.
I'm 99% sure its not the alternator as its a new Denso one. I'll check though.
Are small end failures common on Zetecs?
Stu
whitestu
Stu
whitestu
posted on 11/7/08 at 09:10 PM Reply With Quote
Stu
Jackman
posted on 11/7/08 at 09:21 PM Reply With Quote
Take it you are still on hydrualic lifters ? What grade of oil are you using ?
big_wasa
posted on 11/7/08 at 10:01 PM Reply With Quote
Black tops arnt hydraulic, solid with shims
Be aware that pulling the head to have a look will cost more to rebuild than another engine.
Dusty
posted on 11/7/08 at 10:38 PM Reply With Quote
Whip off the cam cover to inspect the cams and use the trusty feeler gauge to check the 'tappets'. Inlet - 0.15mm. Exhaust - 0.30mm cold.
At least it should identify a cam train fault.
zetec
posted on 11/7/08 at 10:44 PM Reply With Quote
I had a noise very much like a noisy cam when I did a rebuild, turned out the throttle pot was not set correctly meaning the timing was way out, caused pinking which cleared when the revs picked up...really had me going for a while!
bigrich
posted on 11/7/08 at 10:49 PM Reply With Quote
just listened to the video, i would go with the little end theory, sounds to heavy for valve clearences.
D Beddows
posted on 12/7/08 at 02:48 AM Reply With Quote
Small end bearing
Wouldn't affect power, would probably quieten down when the engine was warm - valves hitting pistons wouldn't and you'd probably have broken it properly by now - valve clearance problems would be audible when you revved it from cold......
whitestu
posted on 12/7/08 at 09:48 AM Reply With Quote
So if it's a small end is it likely to fail?
At the moment the car goes really well.
I'm tempted to drive until it pops.
Stu
big_wasa
posted on 12/7/08 at 11:46 AM Reply With Quote
When it does go .................... by by enginge
pist-n-broke
[Edited on 12/7/08 by big_wasa]
whitestu
posted on 13/7/08 at 11:35 AM Reply With Quote
Has anyone got experience of this happening on a Zetec?
stevebubs
posted on 13/7/08 at 01:30 PM Reply With Quote
Stu,
A friend is a driving instructor and had tapetty noises on his last car (sigma powered fiesta). He never got to the bottom of it.
On his current car (same engine), the same noise appeared almost immediately after his first service.
When the car went in for its service, the oil was clear (he changes it every 2-3k miles). When it came out, it was black. Local dealership was obviously using the lowest grade oil it could get away with.
It took 3/4 flushes of the engine to get rid of the noise, and the car no longer goes into the local Ford dealership.
[Edited on 13/7/08 by stevebubs]
stevebubs
posted on 13/7/08 at 01:32 PM Reply With Quote
Just listened to the vid. Definitely louder than the problem my mate had - that was just a clickety click.
jacko
posted on 13/7/08 at 06:20 PM Reply With Quote
Did it make that noise before fitting the bike carbs ? it sounds a bit like mine but louder mine is the carb slides tapping untill you rev the engine its just a thought
Jacko
whitestu
posted on 13/7/08 at 08:25 PM Reply With Quote
Not sure - I've only ever heard it running with bike carbs. I'll check the sildes, but I don't think that's what it is.
Stu
whitestu
posted on 13/7/08 at 08:56 PM Reply With Quote
I've had a good search on google and can't find anything on small end failure in Zetecs.
The oil that came out of the engine was dead clean and there's no noise from the bottom end. The oil light goes out on the starter [not checked the oil pressure though].
I know it's an impossible question to answer, but is it really that likely that the small ends will fail in an otherwise good engine?
Stu
[Edited on 13/7/08 by whitestu]
<<  1    2  >>
