quinnj3
posted on 11/7/08 at 07:37 PM |
Tintop probs audi
Hi my fiancee's car is a 1.6 audi A3 with aircon. The problem is that the traction control light comes on sometimes while she is driving but
does not go off. Then when she stops the car and gets out the fan is running flat out for at least 5 minutes. Does anyone have any idea? I know
someone on here is bound to have an idea as you people know everything!
my aim is to build my own locost wether it takes me a week or 10 years to get started, i'm sure i will sometime
Ketchup
posted on 11/7/08 at 08:00 PM |
does the abs light also come on when the tc light is on?
the fans will sometimes run for a while after you switch off, but i did have a fault on an a3 recently where it would stay on for an hour maybe more!
turned out to be a blocked drain near the cabin filter, alowing water to flow over the blower fan air intake, into the various ecu's and causing
havoc under the dash
quinnj3
posted on 11/7/08 at 08:17 PM |
just had a look there is no water around the pollen filter. Dry as a bone. Only the traction control light comes on and the fans only run on when
the light comes on. It happens about 3 times a week. Thanks for the quick reply
