New Topic New Reply
Author: Subject: brakes
A1
posted on 1/8/08 at 12:18 PM Reply With Quote
brakes
do you need a brake servo for indys? i wouldnt have thought so cause its so light, but thought id better check.
JohnN
no
Mr Whippy
posted on 1/8/08 at 12:22 PM Reply With Quote
no again
mackei23b
posted on 1/8/08 at 12:52 PM Reply With Quote
and no again!
82 Locost
posted on 1/8/08 at 12:53 PM Reply With Quote
No
gingerprince
posted on 1/8/08 at 12:59 PM Reply With Quote
narp
Nosbod
posted on 1/8/08 at 01:02 PM Reply With Quote
nay, nay and .... thrice nay
Bluemoon
posted on 1/8/08 at 01:04 PM Reply With Quote
As it's friday.. One more "helpful" post
No..
Dan
worX
posted on 1/8/08 at 01:29 PM Reply With Quote
nie
indykid
posted on 1/8/08 at 02:18 PM Reply With Quote
no
thebull
posted on 1/8/08 at 02:53 PM Reply With Quote
and its a no again
posted on 1/8/08 at 03:17 PM Reply With Quote
Not as simple as that !
Yes an indy is half the weight of a sierra but you run into a problem with lack of pedal leverage.
For reasonable pedal pressure you need a non-servo (smaller bore) master cylinder.
Westfield use a 0.7" bore master cylinder, Sierra master cylinders are 0.81" or 0.84" bore.
Been covered many times.
Bluemoon
posted on 1/8/08 at 03:25 PM Reply With Quote
O.k only if you site the pivot as low as possible.. British trident, it's a good point, most overlook... I wish that MK would put the master cylinder about 10cm lower than they do it would make the ratio about right (5:1 ish)..
Dan
[Edited on 1/8/08 by Bluemoon]
posted on 1/8/08 at 03:29 PM Reply With Quote
Dan
If they did that your heel would be scraping on the floor... we have a Sierra MC and all is well - the fr/rr bias is great too (we have no bias valve) with disc's on't rear's.
Maradona
posted on 1/8/08 at 03:30 PM Reply With Quote
Nop, the race cars not use servo.
Diego,
The locost builder from Argentina
FASTdan
posted on 6/8/08 at 12:01 PM Reply With Quote
yes....just to be different!
FASTdan
posted on 6/8/08 at 12:04 PM Reply With Quote
Thats interesting to know as I have a rear disc set up from an XR4x4 I was thinking of adding but was unsure of bias complications.
New Topic New Reply
