Author: Subject: Indicator Bar
posted on 2/8/08 at 11:08 AM Reply With Quote
Indicator Bar
A few have asked about it so here you go.....
The bar I made for my indicators is 30x3mm conduit so is fairly sturdy (heavy!) so, one of the reasons I put the bottom rail on to make it stiff.
Here it is on the car...
another angle
Off the car showing the flat bracket that bolts onto the chassis under the headlamp bar...
The bar makes all the worries over sharp edges on the front go away and I didn't even trim the edges of the cycle wings (I take some tho just in case!) I just did the sensible things covering the nuts and wrapping the top ball joint etc. Nothing over the top just makes it a nice tidy job.
*If in doubt, ask*
Valtra
posted on 2/8/08 at 11:15 AM Reply With Quote
an elegant device but did it fall off on the way home from SVA due to the weight ?
posted on 2/8/08 at 11:18 AM Reply With Quote
Emm, no, I've only took it off because someone else wants to 'borrow' it.. cough.
[Edited on 2/8/08 by coozer]
Valtra
posted on 2/8/08 at 01:53 PM Reply With Quote
StevieB
posted on 2/8/08 at 04:11 PM Reply With Quote
So I take it that means they don't do the dreaded 100mm dome test on anything that's behind the bars?
dogwood
posted on 2/8/08 at 05:00 PM Reply With Quote
Thanks Steve
Just what I needed to see.
Now Mr SVA man what are you going to look for next?
Cheers David
posted on 10/8/08 at 11:34 AM Reply With Quote
Correct, no trim on the cycle wings either
