New Topic New Reply
Author: Subject: custom made fuel tanks? where and how much
Antnicuk
posted on 6/8/08 at 09:11 PM Reply With Quote
As above really.
The stylus is running but has the original fuel tank. I'm thinking it holds about 6 gallons but with a turbo rotary doing about 20 mpg at best and about 10 mpg on track, i was looking at getting one made.
I found a place on ebay, just wondered if there was anyone recommended.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
matt.c
posted on 6/8/08 at 09:15 PM Reply With Quote
Try welderman on here. He makes them and they are of a very high standard of quality.
jollygreengiant
posted on 6/8/08 at 09:16 PM Reply With Quote
Your location might be a start. I got mine made by TrevD, but then he is local to me.
clairetoo
posted on 6/8/08 at 09:24 PM Reply With Quote
I made my own - finished up with ten gallons , and a lowered boot floor !
[img][/img]
Its cuz I is blond , innit
Claire xx
Will weld for food......
Alan B
posted on 6/8/08 at 09:32 PM Reply With Quote
OMG......A girl that can weld......I think I'm in love..
procomp
posted on 6/8/08 at 09:33 PM Reply With Quote
Hi caution should be given to the grade of alloy being used. Far to many currently being made with soft 16G alloy and not enough bracing. This allows the tank to expand and contract quite a bit and this causes the seams to be stressed and crack. It will be worse on a larger size tank. So make sure it also has a good breather system fitted To try and reduce the expansion and contraction.
Cheers Matt
imp paul
posted on 6/8/08 at 09:42 PM Reply With Quote
my mate jim at http://www.alloyracingfabrications.com/ he will make any size tank give him a bell he is a top lad
beppesignori
Contributor
Posts 82
Registered 7/8/06
Member Is Offline
Photo Archive Go!
Building: MK Indy Sold. Contemplating V8 midi scratch build
posted on 6/8/08 at 10:49 PM Reply With Quote
I had mine made at Alloy Racing Fabrications. Very high quality and made to my exact specifications. Just sent him a few drawings, along with an alloy plate with studs to mount the fireblade fuelpump to. Perfect fit, and a very good price, too.
[Edited on 6/8/08 by beppesignori]
Antnicuk
posted on 7/8/08 at 11:31 AM Reply With Quote
thanks for the replies.
i', in essex. Claire, is that a stylus?,
Is alloy racing fabrications the one that advertises on Ebay?
welderman
posted on 7/8/08 at 12:44 PM Reply With Quote
u2u me some sizes, i can give you a price if you want.
Thank's, Joe
I don't stalk people
clairetoo
posted on 13/8/08 at 12:02 PM Reply With Quote
Nope - it's a fury (I had to cut the body in two to remove it for the re-build)
[Edited on 13/8/08 by clairetoo]
Claire xx
New Topic New Reply
