Author: Subject: Bolting on Cycle Wings
Kriss
posted on 17/8/08 at 05:28 PM Reply With Quote
My cycle wing just doesnt want to stay on on the drivers dide, not matter how much it is keyed, preped or what grab glue etc i use.
Can comeone point me in the direction of small black bolts and nut to scre the buggers on. been on screw fix but no joy in anything that small. imagine 10mm or tops 15mm
pref black
stuart_g
posted on 17/8/08 at 05:34 PM Reply With Quote
Motorcycle fairing bolts. you can get them in all sorts of colours.
Jon Ison
posted on 17/8/08 at 05:39 PM Reply With Quote
Have you tried tiger seal ?
I could tow the car puling on the cycle wings stuck on with this stuff ?
TimC
posted on 17/8/08 at 05:44 PM Reply With Quote
Yeah - I used the tiger seal equivalent from Car Builder Solutions. There's no way that they're coming off - and that's with CSR arches that don't butt-up flat against the wingstay at the back.
You're not doing something right Kriss.
[Edited on 17/8/08 by TimC]
TOO BADD
posted on 17/8/08 at 06:23 PM Reply With Quote
Tiger seal on my wings no probs
charlierevell
posted on 17/8/08 at 07:27 PM Reply With Quote
demon thieves do black dome head allen key bolts... can choose dia. and length on the site
Tango orange is an 'IN' colour!!
Simon
posted on 17/8/08 at 07:34 PM Reply With Quote
I fibreglassed mine in place.
Simon
Kriss
posted on 17/8/08 at 08:59 PM Reply With Quote
just stickaflexed the bugger with two g clamps. It's only the drivers side one that's being an issue. If they do not stay on I will have to bolt them. Cheers chaps
DarrenW
posted on 18/8/08 at 08:31 AM Reply With Quote
Proper sikaflex is good. I used Wurth Bond and seal.
As said before sounds like you arent doing something correctly. Is wing stay arm painted? rusting underneath? This would lessen the adhesion.
i cleaned arm to bright steel and roughened it. Cleaned underside of arch. Thich bead of seal on arm and held in place until set. Then applied more underneath. Arm totally covered (mine as well as wing stay arm), total area probs 6" wide. Obviously not so thick that it touches tyre. No probs in last 3 years and wing stay / arch assy was taken off 18 months for repainting and cosmetic work. Defo stuck well.
posted on 18/8/08 at 06:14 PM Reply With Quote
I formed some 25mmx 3mm steel to the shape of the wing, drill and tapped for a 6mm stud which was then welded as well then drilled the wing stays , bolted the strips to the stays and then used Sikaflex to stick the stips to the wings (clamped in place until set. ) W ings are removable and have no bolts showing . Not had any problems with this method even when the wings stays have broken.
