Author: Subject: R1 Engine Oil - links please
Kriss
posted on 19/8/08 at 12:17 PM Reply With Quote
Hi chaps,
trying to find what oil to use on my 5pw R1. All the sites at work that are forum based seemed to be blocked from my google searches.
Heard Castrol GPS semi synthetic is good, but what viscosity 10w-30? 40? ahhhh!!!!
Dangle_kt
posted on 19/8/08 at 12:25 PM Reply With Quote
10/40 is a good weight.
What engine oil is in there now? Semi Synth, fully synth? Mineral?
You can swap and change but I have read swapping can lead to clutch slip (i think it is becuase the old type of oil contaminates the clutch plates and the new type of oil acts as a barrier thereby reducing friction - therefore reducing drive)
You dont want clutch slip in a bec so I sugest you check out what you have and match it.
That happens in bikes anyway.
I'm sure someone clever wil be along soon to put us both straight.
r1_pete
posted on 19/8/08 at 01:05 PM Reply With Quote
DON'T use car oil in the bike engine, the addatives are not compatible with the wet clutch. I use Halfords fully synthetic bike oil in my R1, I ride it very hard and never had any problems.
Kriss
posted on 19/8/08 at 01:26 PM Reply With Quote
cheers chaps
what "numbers" shall i go for though?
10w-30 10w-40??????
r1_pete
posted on 19/8/08 at 01:42 PM Reply With Quote
Its this stuff I use...
Rgds.
Pete.
posted on 19/8/08 at 01:53 PM Reply With Quote
For my ST I use Putolene semi-synthetic
For an R1 I might push the boat out and get something fully synthetic. Semi-synthetic is (at the end of the day) a bit of a fabrication IE it's normal oil with modifiers in it but people go for it (me included) in the same way that most people don't go for the house wine in a restaurant but the second cheapest (even though it's often worse quality than the house!!).... but I digress....
progers
posted on 19/8/08 at 04:08 PM Reply With Quote
Ideal oil viscosity for an R1 is 10W40.
I personally have used Castrol GPS and R4 (fully synth) with good results. There is no reason why other (quality) brands won't be equally effective. Nice thing about Castrol is you can get it almost anywhere (including Halfords).
Paull
trottski
posted on 19/8/08 at 07:10 PM Reply With Quote
I use Silkolene Pro 4 15-50 in my R1 4XV engine.
http://www.opieoils.co.uk/p-1142-silkolene-pro-4-15w-50-full-synthetic-ester-4-stroke-engine-oil-for-all-high-performance-motorcycles.aspx or http://performance-oils.co.uk/acatalog/Silkolene.html
bassett
posted on 20/8/08 at 10:17 PM Reply With Quote
Hi, if you need it local and soon Castrol Power Racing1 10w-40
Adam
[Edited on 20/8/08 by bassett]
Kriss
posted on 21/8/08 at 12:16 PM Reply With Quote
Adam, can you hook me up from work wink wink?
richardh
posted on 21/8/08 at 12:30 PM Reply With Quote
10/40 on mine (that's what MNR suggested for my Carb R1)
