Author: Subject: Zetec Blacktop sump on silvertop
whitestu
posted on 24/8/08 at 08:37 AM Reply With Quote
I'l on the lookout for a replacement for my knocking blacktop engine and don't want to shorten the sump again.
Does anyone know any reason why a blacktop sump won't fit a silvertop?
Stu
Dusty
posted on 24/8/08 at 09:06 AM Reply With Quote
The mating flange on the bottom of the blocks is the same. Blacktop sump has the oil baffle/wiper/seperator (can't think of the correct term) plate cast into the ally section of the sump. The silvertop has a steel plate bolted to two and four main bearing caps. The caps on the silvertop are taller also. I know the blacktop sump will not just drop on the silvertop. I do not know if it can be fettled to fit as I haven't tried but I think it's a no!
Dusty
posted on 24/8/08 at 10:00 AM Reply With Quote
Windage, that's the word I was groping for! I have a sump and bare-arsed silvertop in the garage. Will go and have a play.
whitestu
posted on 24/8/08 at 10:08 AM Reply With Quote
Rob, which bit of the cap bolts do you cut down?
Stu
Dusty
posted on 24/8/08 at 11:51 AM Reply With Quote
Just measured up. The webs in the sump that align with the main caps and stiffen the windage tray will need shortening/grinding down quite a bit. This confirms my recollection of the main caps being taller on the silvertop than the blacktop. Also may need some adjustment of the oil pickup but I would amend my first doubts to 'probably do-able' with a fair bit of ally grinding. Rescued attachment black on silver.jpg
whitestu
posted on 24/8/08 at 11:58 AM Reply With Quote
Thanks guys - that Sounds OK then. I don't mind a bit of chopping and grinding to get it to fit.
Have you used an Escort water pump on your silvertops?
Stu
Dusty
posted on 24/8/08 at 12:04 PM Reply With Quote
Yes. 1800 escort pump.
whitestu
posted on 24/8/08 at 02:34 PM Reply With Quote
Stu
