Author: Subject: degreasing plastic
jabbahutt
posted on 4/9/08 at 08:47 AM Reply With Quote
degreasing plastic
Morning all
Quick question, I have some 2nd hand plastic vents for the top of the bonnet for after SVA.
At the moment they're a bit oily and could do with a degrease before spraying. What would be the best thing to use that won't harm the plastic or leave any residue but get's it nice and clean.
I was thinking of washing up liquid but thought I'd check if anything was better first.
Nigel
owelly
posted on 4/9/08 at 09:06 AM Reply With Quote
Dishwasher
http://www.ppcmag.co.uk
speedyxjs
posted on 4/9/08 at 09:12 AM Reply With Quote
Originally posted by owelly
Dishwasher
It would ahve to be pretty tough plastic. You cant put plastic cups in hte dishwasher
whitestu
posted on 4/9/08 at 09:31 AM Reply With Quote
Most plastic is fine in the top of the dishwasher.
Stu
iank
posted on 4/9/08 at 09:58 AM Reply With Quote
I'd use Isopropyl alcohol but that's mainly because I have a can and I'm certain it wouldn't damage plastic.
Brake cleaner might work, but test a non visible area first just in case.
Anonymous
Spyderman
posted on 4/9/08 at 10:07 AM Reply With Quote
Washing up liquid should be fine.
To make sure you could always follow that with white vinegar and water solution. Excellent for degreasing.
Spyderman
jabbahutt
posted on 4/9/08 at 10:38 AM Reply With Quote
Thanks all I can crack on with this while the weather is so shockingly bad.
posted on 4/9/08 at 12:12 PM Reply With Quote
Thinners on a rag, if it's a car part it should wipe over with no problem.
posted on 4/9/08 at 01:56 PM Reply With Quote
I'd be wary of using things like carb cleaner / brake cleaner (having watched the plastic tray I filled with carb cleaner to rinse things in melt and collapse!!)....
If it's for cosmetic appearance a soak in some fairy liquid and a scrub should suffice....
