mads
posted on 4/9/08 at 03:29 PM |
sierra column and escort rack
hey all,
just wondered is it possible to use a sierra steering column with a escort steering rack in a MK Indy? only reason i ask is that the quickest racks
for a sierra i've been told are 2.8 but there are 2.4's for the escort. are there any issues that might arise from using this combo?
i've seen a sierra column coupling on RD
[Edited on 4/9/08 by mads]
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Rob WM
posted on 4/9/08 at 03:31 PM |
The Dax MC uses this arrangement, so assume it is ok. Just not sure of the alteration to the lower column.
adam1985
posted on 4/9/08 at 03:32 PM |
yeah thats the setup most use including me mines a mk 2 escort rack
Rob WM
posted on 4/9/08 at 03:37 PM |
Can't see any problem then. The mounts for the rack will be different no doubt but show you can alter those.
posted on 4/9/08 at 03:39 PM |
The drop link from thecolumn justs needs to be made with the approriate UJ's at either end.
ashg
posted on 4/9/08 at 03:56 PM |
standard setup on the haynes version. shouldnt be a problem
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mads
posted on 4/9/08 at 04:09 PM |
cheers guys. anyone with a MK Indy R who has used this setup and can advise on the different bits I will need or the mods I need to tell MK about
before I pick up my kit e.g. do i need different u/j's and if so, which ones?
Danozeman
posted on 4/9/08 at 09:58 PM |
If your getting a kit id just tell MK what u want to do. Im sure they will know what to do. YOul need different mounting plates on the chassis and
the steering shaft will need a different end on. MK will soon sort that for you.
Dan
