Author: Subject: Which foam and where to buy?
beppesignori
Contributor
Posts 82
Registered 7/8/06
Member Is Offline
Photo Archive Go!
Building: MK Indy Sold. Contemplating V8 midi scratch build
posted on 6/9/08 at 09:13 AM Reply With Quote
I need to make up a slightly modified bonnet bulge to accomodate the secondary injector fuel rail on my CBR engine. Idea is to make a positive mold ind just lay the glass over it. Working with foam is probaly the easiest, but which foam should I use, and where do I get it?
Cheers, c
tegwin
posted on 6/9/08 at 09:15 AM Reply With Quote
I have used building insulation foam before....Comes in 6" thick sheets...
BUT....The resin will desolve the foam...
So once you have made up your shape....cover it in packing/duct tape and then lay your resin over it....
Once its cured, pour petrol over the foam to desolve it....or peel it out etc..
www.verticalhorizonsmedia.tv
iank
posted on 6/9/08 at 09:35 AM Reply With Quote
The 'proper' stuff is polyurathane foam which doesn't react with the resin - but still needs a shiny coat to stop the it sticking.
CFS stock it, but it's a lot more cash than B&Q building foams.
http://www.cfsnet.co.uk/acatalog/CFS_Catalogue__FOAMS___CORE_MATERIALS_129.html
Anonymous
Benzine
posted on 6/9/08 at 09:45 AM Reply With Quote
Yeah it eats away at it. I took mr whippy's advice and put a couple of layers of PVA over it, made a good seal and then it wouldn't dissolve
twybrow
posted on 6/9/08 at 12:56 PM Reply With Quote
Buy a can of expanding foam from B&Q etc. It is normally PU and should be good with most resin systems you try. Shape it, then spray with automtive paints, then coat with wax and or PVA. Done.
posted on 6/9/08 at 01:24 PM Reply With Quote
Floral foam (otherwise known as Oasis foam) is compatible with most polyester resins.... It's also compatible with car body filler (bondo).
