Author: Subject: MNR in Sweden
Triggerhappy
posted on 8/9/08 at 09:41 AM Reply With Quote
MNR in Sweden
will order Kit when engine landed safley in my garage..hopefully later this week.
Planning on Nova“s drysump kit.
Are still uncertain what really differs the Super and RT+ except material in frame?? A lot of £££ differs??
[Edited on 17/9/08 by Triggerhappy]
TimC
posted on 8/9/08 at 09:46 AM Reply With Quote
I think that's the main difference. I also have a feeling that all the carbon trim bits are standard on the Super - I'd have to check the website to be sure though. I did consider going for the Super but figured that I'd never really see the benefit. As it is, I've bought a load of other carbon parts anyway since.
GREAT choice of engine!!!
smart51
posted on 8/9/08 at 10:12 AM Reply With Quote
Don't you have strict power to weight regulations in Sweden? How heavy do you have to make the car for an 08 Busa?
Agriv8
posted on 8/9/08 at 11:12 AM Reply With Quote
I belive the main cost is soaked up in the difference in price between the
t45 tube used in the Supper
and
the Standard tube RT+
Mutiply this by the ammount of tube in an Vortx.
You can feel the difference in weight when picking up a Meter of Standard and a Meter of T45.
All the best
Agriv8
Triggerhappy
posted on 8/9/08 at 11:19 AM Reply With Quote
Yes, you are right.
max 15Kw/100Kg. Less 70Kg driver and full tank. So a bit more than 800Kg exkl driver
Triggerhappy
posted on 8/9/08 at 11:23 AM Reply With Quote
and
All the best
Agriv8
The tubewall thickness need to be 1,6mm for T45 to be accepted for registration so weight gain is a bit less...if i understand the situation correctly.
To my knowledge there are just 2 MNR“s in Sweden. Both are in building process, both with busa“s. One RT+ and one Super.
What weight saving would an Super have for an equally equipped RT+ ??
TimC
posted on 8/9/08 at 11:24 AM Reply With Quote
Yes, you are right.
Lead seats?
max 15Kw/100Kg. Less 70Kg driver and full tank. So a bit more than 800Kg exkl driver....during registration process....
Triggerhappy
posted on 8/9/08 at 08:09 PM Reply With Quote
Originally posted by TimC
Lead seats?
Diff? Will Busa work with 3,14 or should i go for the shorter 3,38??
Car will see alot of track...mainly on 13" r-tyres and/or Slick....
[Edited on 20/9/08 by Triggerhappy]
fege
posted on 8/9/08 at 08:25 PM Reply With Quote
There is another one beeing built in my garage. It's a R1 powered RT with inboard front suspension. There are also two CECs being built by a guy in vasteras.
Triggerhappy
posted on 14/9/08 at 09:34 AM Reply With Quote
Picked up this gem this friday
Agriv8
posted on 15/9/08 at 07:04 AM Reply With Quote
MNR can advise - but If you can get them easy enought get both as they are getting rare.
regards
Agriv8
Triggerhappy
posted on 15/9/08 at 08:37 AM Reply With Quote
Car will be built to perform on track, so all 13" R tyres and Slick.
Still a bit uncertain about diff choice.
Quaife ATB will be used.
But as you mention...3,14 or 3,38...thats the big question...??
Is the ATB really necissary?? BIG ££
[Edited on 15/9/08 by Triggerhappy]
Triggerhappy
posted on 29/9/08 at 01:10 PM Reply With Quote
I went with the 3,38.
Planning my fuel system...prefilter, pump, fine filter and regulator.
Any hot suggestions.
Anybody familiar with Bosch pumps??
Suggest an part no to give >3bars at aprox 180L/h
pwl
posted on 29/9/08 at 03:27 PM Reply With Quote
Bosch partnumber 0580464070 is 3 bar 195L/h
PWL
Triggerhappy
posted on 7/11/08 at 12:12 PM Reply With Quote
My VortX is on the road now!!!
In the crate thou
Expect my garage to fill up mid next week...christmas is early this year
