Author: Subject: Xflow rattle
Chris Leonard
posted on 7/1/04 at 11:39 AM Reply With Quote
Xflow rattle
On starting up the 1300 Xflow for the first time the other day: It started on the button and ticks over and revs no problem. But before the engine is fully warm, when you rev it up, as the revs drop there is a rattle (more a rattling sound than a knocking) coming from the back end of the engine sort of riund the clutch starter area.
Once the engine is warm it's OK.
Any idea's! (I fear the worse!)
posted on 7/1/04 at 11:43 AM Reply With Quote
Which end's the timing chain? I've got a X-flow but I can't remember! (I suspect it's on the other end, up-front)
DJ
Chris Leonard
posted on 7/1/04 at 12:27 PM Reply With Quote
yep thats up the other end
posted on 7/1/04 at 12:55 PM Reply With Quote
Fair enough!
In that case, my first suspect would be tappets on cylinder No. 4.
DJ
Chris Leonard
posted on 7/1/04 at 01:07 PM Reply With Quote
I checked them - its more down the bottom end but just at the back. Could be the clutch - although its a new one I put in. Im hoping its not the big ends or something like that, but if it where the big ends would it be so specificly from that area. Any idea if the ends have gone wether it would quieten up when warm?
posted on 7/1/04 at 01:22 PM Reply With Quote
If it was my engine, I'd ask myself the following questions...:
Am I seeing any blue smoke when I blip the throttle?
Have I got good compression in all the cylinders?
Have I got good oil pressure?
Did I tighten up the nuts on the flywheel and clutch before I attached the gearbox?
In my (limited) experience, worn big end bearings tend to give out a rumble on tick-over, which goes away when revs rise.
Anyone else got any ideas? I'm only pretending to know what I'm talking about!
DJ
[Edited on 7/1/04 by David Jenkins]
theconrodkid
posted on 7/1/04 at 05:18 PM Reply With Quote
try dipping the clutch,my release bearing does that when she hasnt been used for a week or so
who cares who wins
pass the pork pies
stephen_gusterson
posted on 7/1/04 at 05:37 PM Reply With Quote
check that the oil pressure switch is.....
nah, thats too cruel steve
Id go for a release bearing noise. Does it change if you depress the clutch?
atb
steve
Chris Leonard
posted on 8/1/04 at 09:24 AM Reply With Quote
I started it up again last night.
No blue smoke - the oil pressure was around 45 on tickover (smiths gauges)
The noise didnt totally disapear when I put the clutch in - its only on the overrun after reving it up.
Hopefully I will be able to get someone over to have a listen
stephen_gusterson
posted on 8/1/04 at 10:01 AM Reply With Quote
where is the distributor on a xflow? could it be something worn or the advance / retard mechanism rattling?
atb
steve
posted on 8/1/04 at 10:22 AM Reply With Quote
atb
steve
Steve,
It's on the starboard side, near the front of the engine. Probably not a suspect...
Spyderman
posted on 8/1/04 at 02:49 PM Reply With Quote
That sounds like it could be the bearing in the flywheel for the input shaft.
Have you tried jacking the rear wheels off the ground and running it in gear?
Does it still rattle as much?
Terry
Spyderman
Mk-Ninja
posted on 8/1/04 at 03:06 PM Reply With Quote
Running it out of gear will do the same thing without having to jack it up
[Edited on 8:1:04 by Mk-Ninja]
I'm sure I've got one, just don't know where I've put it
Highcost builder
posted on 8/1/04 at 05:21 PM Reply With Quote
No it wont, it could be the lay shaft bearings and in gear the shaft will have a load on it and the noise would stop.
Mk-Ninja
posted on 8/1/04 at 05:32 PM Reply With Quote
Point taken, I was just thinking about the clutch bearing
Stu16v
posted on 8/1/04 at 05:54 PM Reply With Quote
If the noise is *just* on the overrun, I doubt that it is clutch related.
I'm concerned that it might be a piston or a little end complaining, especially as it improves with temperature. And a Xflow weakness unfortunately, especailly if it has been 'driven', so to speak....
david walker
posted on 8/1/04 at 08:19 PM Reply With Quote
Timing chain / tensioner pad / snail cam & spring ?????
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
posted on 8/1/04 at 10:09 PM Reply With Quote
That's why I asked about blue smoke, oil pressure and cylinder compression...
DJ
cobby
posted on 8/1/04 at 10:49 PM Reply With Quote
It could be piston slap on No 4 cylinder, if it doesnt get any worse then dont worry too much. If oil pressure is ok and it doesnt smoke then just drive it. If it really bothers you then take the engine out and strip it. If it was mine then I would drive it untill or if it blows up. Crossflows are easy to come by and cheap.
Chris Leonard
posted on 9/1/04 at 05:58 PM Reply With Quote
Thanks for the replies - I think I'll just ignore it for the moment. My main concern is when I get the SVA done - don't know what they will say about it there. I know it doesn't come under anything in the SVA manual but I dont want to encourge them to look too closely at anything!
