Author: Subject: R1 blowing out oil plugs
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 4/10/08 at 05:32 PM Reply With Quote
At both the last two track days I have been to, my R1 engine has lost the oil fill plug.
The first may have been bad luck with a loose plug but the second I tightened it by hand as tight as I could (though my mate may have over filled it with oil after the first time).
I now have an aluminium plug which I intend to lock on but was wondering if the above is a sign of bigger problems, or just a blocked breather or channel or something.
ps .
mangogrooveworkshop
posted on 4/10/08 at 05:33 PM Reply With Quote
possibly blocked sump vent or blow past on rings
adithorp
posted on 4/10/08 at 06:58 PM Reply With Quote
I can't see crank-case presure unscrewing it. Sound like it just wasn't tight enough and heat and vibration did the rest.
adrian
http://jpsc.org.uk/forum/
Tangerine Scream
posted on 4/10/08 at 08:44 PM Reply With Quote
Yup, lost one due to vibration (I think)
Drilled a hole and lockwired the new one to a nearby bolt and hasn't come loose since
hobbsy
posted on 4/10/08 at 10:56 PM Reply With Quote
Apparently this is fairly common.
I drilled a hole though the plug and got a big spring to put tension on it and stop it vibrating loose.
I would've wired locked it but CBA to keep re-doing it if topping up or changing oil.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 5/10/08 at 05:33 PM Reply With Quote
That is good news!
I'll fit the new one (and fit the new prop shaft) and hope for the best Saturday at LLandow.
TimC if you are out there I should be there all day.
Cheers all.
Ed
adithorp
posted on 6/10/08 at 10:59 AM Reply With Quote
I've just seen this while looking for something else. Halfway down the page.
http://www.robcollingridge.com/kitcar/design/engine/index.html
adrian
TimC
posted on 6/10/08 at 12:30 PM Reply With Quote
Cheers all.
Ed
Hi Ed. I won't make it I'm afraid. I'm off to Mallory on Sunday to watch the racing so Saturday will have to be my MBA study day.
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
posted on 8/10/08 at 06:01 PM Reply With Quote
Well spotted Adrian! I'll see if that works with the Ali one.
Tim, what is more important, a career or a day at Llandow?
TimC
posted on 9/10/08 at 08:13 AM Reply With Quote
Watching has become VERY frustrating!
