nathanharris1987
posted on 5/10/08 at 04:36 PM |
which glue?
which glue should i go for with glueing a sheet of aluminium to the rough side of fibreglass? preferably one thats cheap in bulk as i suspect
i'll need a fair bit of it.
ta
Nath
posted on 5/10/08 at 04:51 PM |
Aliminium to GRP?
Make sure you rough up the aliminium surface first (makes a huge difference).
You could use epoxy (it'll stick to dry polyester GRP and ali nicely). I'd shy away from polyester as you'll likely just get a thin
film that will delaminate.
That would be my choice (unless you're gluing shed loads on in which case it'll get a bit expensive). You could mix in some micro
balloons- otherwise if the back surface is bumpy you'll end up with quite a thick overly-strong layer of epoxy.
jamiepearson69
posted on 5/10/08 at 04:54 PM |
'Gripfill' Bonds just about anything to anything, you will probably not get it off again!
nathanharris1987
posted on 5/10/08 at 05:13 PM |
ta lads, will look into it, its just to reinforce my dash before i fix it down as its wobbling all over the shot,
thanks again
nath
jacko
posted on 5/10/08 at 05:46 PM |
Tiger sealer / Sikaflex / or any pu sealers
sand the ally first
Jacko
RickRick
posted on 5/10/08 at 08:47 PM |
if it needs to be stuck good and proper, drill loads of small holes into the alli
