Author: Subject: r1 carb swaped for r1 throttle bodies?
robbydee
posted on 6/10/08 at 07:58 PM Reply With Quote
As i already have a manifold will i be able to use it?
Any advice on r1 throttle bodies.?
currently have pinto with r1 carbs..and megajolt.
lsdweb
posted on 6/10/08 at 08:11 PM Reply With Quote
The spacing is slightly different!
robbydee
posted on 6/10/08 at 08:13 PM Reply With Quote
typical..
omega0684
posted on 6/10/08 at 08:28 PM Reply With Quote
you can use the same manifold, i did, they are only of by a couple of mm, you can only see the difference on one cylinder.
robbydee
posted on 6/10/08 at 08:33 PM Reply With Quote
what else did you need to do the conversion..
im thinking..
megasuirt
fuel pump
swirl pot and return to tank.
sensors etc.
lambda.
lsdweb
posted on 6/10/08 at 08:34 PM Reply With Quote
I fitted TB's to a carbed R1 and it was OK but they were a bu**er to fit and wouldn't stay on for long!
