Author: Subject: Revving X-Flow Engine
thepest
posted on 7/10/08 at 03:59 PM Reply With Quote
Erm more of an alternator question really, If I have the engine revving to 8K, would there be any damage to the Alternator?
Should I make it disconnect at a set RPM or would that be pointless?
Paul TigerB6
posted on 7/10/08 at 04:06 PM Reply With Quote
Depends on the size of the pulleys and the rev limit of the alternator you are using really. I found with the setup i had as supplied by Tiger Sportscars i was revving beyond the specified limit for a Lucas LRA101 of 14,000rpm - found out after frying my 3rd alternator so fitted a Nippondenso one which was smaller and safe to 18,000rpm.
A bigger pulley on the alternator will slow it down
[Edited on 7/10/08 by Paul TigerB6]
clairetoo
posted on 7/10/08 at 04:56 PM Reply With Quote
Or a smaller crank pulley - which will also slow down the water pump .
Its cuz I is blond , innit
Claire xx
Will weld for food......
posted on 7/10/08 at 05:06 PM Reply With Quote
Could be wrong but IIRC the steel crank pulley from Burtonpower is smaller and worth fitting just for reliability as the standard one will self destruct
clairetoo
posted on 7/10/08 at 06:31 PM Reply With Quote
Which reminds me - I found a one of those in the shed when I tidied up the other week
Any one need one ?
Claire xx
andrews_45
posted on 7/10/08 at 07:04 PM Reply With Quote
u2u sent bout the crank pulley
thepest
posted on 8/10/08 at 06:43 AM Reply With Quote
Got that all done with the pulleys, but wont it be running too slow at low rpm?
posted on 8/10/08 at 08:38 AM Reply With Quote
That's the trade off. Output will be lower or possibly even zero at idle.
Paul TigerB6
posted on 8/10/08 at 08:42 AM Reply With Quote
But is a great excuse to rev the nuts off it!!
I'm sure you will be fine in normal driving conditions - so long as you dont start it and just leave it idling before switching off all of the time
posted on 8/10/08 at 06:46 PM Reply With Quote
You shouldn't have to worry about cold starting, heater, heated rear window, ICE etc so the electrical loads will be lower so a lower charging rate will be OK . I have a steel crank pulley etc on my Xflow and have no starting problems and our weather is much cooler than yours.
thepest
posted on 8/10/08 at 09:11 PM Reply With Quote
Thanks Guys, newly rebuilt engine going in....
(Excuse the mess in the garage)
Xflow goin in
Xflow goin in
clutch_kick
posted on 9/10/08 at 04:56 PM Reply With Quote
mess? What mess? that is spotlessly clean compared to the other garage lol
