Author: Subject: Question for a welder!
Chippy
posted on 9/10/08 at 09:59 PM Reply With Quote
Hi, I tried to weld an R1 can onto my S/S exhaust pipe, and as you can see from the attached picture it definately didn't work, the weld seems to have cristalised. I have welded many S/S items in the past and never had a problem, well at least not like this. Any idea's why it should happen??????? Cheers Ray.
Image deleted by owner
maximill666
posted on 9/10/08 at 10:02 PM Reply With Quote
Your R1 can pipework is Titanium
907
posted on 9/10/08 at 10:06 PM Reply With Quote
Is an R1 can titanium?
(Titanium gives off brilliant white sparks if touched with a grinder.)
Paul G
bigrich
posted on 9/10/08 at 10:09 PM Reply With Quote
as above, thought they were made of titanium
Chippy
posted on 9/10/08 at 10:10 PM Reply With Quote
Well if it is Titanium, (although must say it "looks" like S/S), can it be welded, and if so how? Ray
maximill666
posted on 9/10/08 at 10:11 PM Reply With Quote
Early R1 Cans (4XV) are stainless with a carbon sleeve, and then changed to titanium sleeves & pipework 2000-2001 (5JJ)
Mark G
posted on 9/10/08 at 10:12 PM Reply With Quote
Tig?
907
Not to stainless Ray
mark chandler
posted on 9/10/08 at 10:15 PM Reply With Quote
I have chopped two R1 cans now, both stainless.
Are you using TIG ? For a proper job you should backgas but as its thick I never bothered and mine have both been fine.
If you drill the rivits and knock off the ali cover the tube is welded to a mild steel case.
nb/ Titanium is just the end cap on a GSXR can, they do not make these out of this stuff as its expensive, just have little finishers... then call it a Titanium can !
[Edited on 9/10/08 by mark chandler]
maximill666
posted on 9/10/08 at 10:24 PM Reply With Quote
[If you drill the rivits and knock off the ali cover the tube is welded to a mild steel case.]
On A 5JJ exhaust can only the top end cap below the ali cover is mild steel (tailpipe end), the bottom one is titanium just like the pipework
maximill666
posted on 9/10/08 at 10:34 PM Reply With Quote
[Well if it is Titanium, (although must say it "looks" like S/S), can it be welded, and if so how? Ray ]
As Paul G said, unfortunately NO
Titanium cannot be fusion welded to stainless steel.
[Edited on 9/10/08 by maximill666]
Chippy
posted on 9/10/08 at 10:39 PM Reply With Quote
Well just one word for it, bu**er!!!!! More cash down the drain, Ho Hum! Ray
MakeEverything
posted on 9/10/08 at 11:17 PM Reply With Quote
or make the rest of the system titanium....
Kindest Regards,
Richard.
speedyxjs
posted on 10/10/08 at 06:50 AM Reply With Quote
Might empty your pockets though
quattromike
posted on 10/10/08 at 12:01 PM Reply With Quote
What about soildering them together that should work? but you'l need to slip one inside the othwer a bit and I'd say use silver soilder too which is expensive
"At the end of the day, I think it's going to get very dark"
wilkingj
posted on 10/10/08 at 12:09 PM Reply With Quote
Split the pipe, insert a sleve, and two Jubilee Clips (or similar) to secure.
What else can you do if it cant be welded?
Best Regards
Geoff
http://www.v8viento.co.uk
Chippy
posted on 10/10/08 at 10:22 PM Reply With Quote
Have hacked one can about and I think I have the solution. I have drilled out the rivets, removed the end cap. Ground away the tail pipe completely, and drilled out the rivets that hold the titanium plate to the steel inner. I am now going to make a stainless plate that will rivet back into the six holes with the piece of S/S pipe welded to that, jobs a good un! (hopefully) :-) Cheers Ray
