Author: Subject: ZX9 speedo error calculation
MK9R
posted on 14/1/04 at 10:47 AM Reply With Quote
I am using a 3.62 diff and 195-50-15 tyres and just wanted to know what sort of error i would be getting when using the zx9 clocks, so i have been doing some maths:-
If i used the 4 pick up lugs on the drive flange (as per the bike) i would get a
+35.2% reading.
I have actually fitted 3 lugs rather than 4 to reduce the error, this gives me a +13.6% reading
NB. All calculations assume that the guages are 100% accurate (which they obviously are not).
Just to check, is this error OK for SVA??
As i am making new dial faces i may increase the spacing of the scale by 13% to make up for this.
[Edited on 14/1/04 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Mk-Ninja
posted on 14/1/04 at 06:54 PM Reply With Quote
Ive been looking at this, but the bit I dont know is what the original revs of the front sprocket to the distance traveled by the bike, because that must be built into the electronics somewhere.
Ive got a gearing spreadsheat for a BEC if you want it.
Gordon
I'm sure I've got one, just don't know where I've put it
MK9R
posted on 15/1/04 at 07:42 AM Reply With Quote
i've already got it. Its what i used to do my calculations with. cheers
Cheers Austen
RGB car number 9
www.trackace.co.uk
Mk-Ninja
posted on 15/1/04 at 08:27 AM Reply With Quote
Well dont share it then
MK9R
posted on 15/1/04 at 08:31 AM Reply With Quote
here you go then, can't be arsed to tell you what everything is though
Cheers Austen
RGB car number 9
www.trackace.co.uk
Mk-Ninja
posted on 15/1/04 at 08:35 AM Reply With Quote
