philhoward
posted on 26/10/08 at 08:20 AM |
Wanted Copper pipe/fittings
I am planning the conversion to a Polo radiator in my Tiger cat and need the following
500mm long 35mm copper pipe
2 off 35mm 90° elbows (solder joint)
1 off 35mm/35mm T to 15mm (solder joint)
Does anyone have anything knocking about that they want to get rid of, or know of a cheap source? I have tried my local plumbers merchants but they
only want to sell me a 3 metre length.
posted on 26/10/08 at 08:23 AM |
i got mine froma plumbers merchant, bloody expensive. I do recall seeing a large pipe in the garage, will have a measure up this eve. u2u me if i
forget! No fittings though, you may have to bit the bullet there, probably a tenner each!
ballcock
posted on 26/10/08 at 08:27 AM |
Are you friendly with your local scrap dealer? Mine's a great source for so many odd bits
bob tatt
posted on 26/10/08 at 09:45 AM |
dont have any spares or tube like above try the scrappies for the tube as they will only sell in 3m lenghts industry standard im affraid, as for the
fittings do you know anyone who works on big sites could be some swapping going on with the plumbers
Mal
posted on 26/10/08 at 10:29 AM |
try www.bes.co.uk
mail order plumbing components
adam1985
posted on 26/10/08 at 11:03 AM |
you will have to buy the pipe in 3 meter lengthd is you get it new and it aint cheap about £30-£35 i think
r1_pete
posted on 26/10/08 at 11:58 AM |
Pipe
HERE
