Author: Subject: Xmas Presents
m8kwr
posted on 3/11/08 at 08:43 AM Reply With Quote
Xmas Presents
With xmas approaching, i am getting asked with what i want this year, instead of getting socks.
I want to get presents this year that i will actually use towards building a car.
So, i was wondering what tools have people used to build there cars which they would not do without, which are not on the list below.
Things i have so far.
Axle stands
Welder
trolley jack
Tool cabinet
lots of general tools, drill bits, screwdrives, spanners
angle grinder (4 1/2 inch)
Drill
Inspection light
Things that i was thinking about are
Vice
Drill Press
Pipe bender
Grinding station
New socket set (probably teng tools)
lClamps - But what are the best when welding a chassis?
Many thanks.
[Edited on 3/11/08 by m8kwr]
Mr Whippy
posted on 3/11/08 at 08:46 AM Reply With Quote
I broke so many of my teng tool socket set (also a Christmas present from my folks), including snapping my long lever bar trying to remove the Beetles rear hub nut (by hand, no scaffold tube) I instead replaced them with proper Halfords professional ones and they are still in perfect condition.
Also get a set of ratchet spanners, more clicks the better
[Edited on 3/11/08 by Mr Whippy]
smart51
posted on 3/11/08 at 09:28 AM Reply With Quote
I second a dremmel. I cut and filed the holes in my GRP bodywork by hand. A dremmel is worth every last penny for this job.
maartenromijn
posted on 3/11/08 at 09:30 AM Reply With Quote
A vice and a drill press are essential, to my opinion. What is useful are those triangular welding magnets. some more ideas:
- Steel wire brush and cutting discs for your angle grinder.
- Stands for the chassis
- this (don't know English word)
- leather gloves
- and more!
BLOG: http://thunderroad-super7.blogspot.com/
iank
Couldn't live without a vice, 4" at a pinch, 6" preferably - though they sometimes come up for beans at car boots coz no-one wants to carry them home.
Get some decent sockets and spanners. The Halfords professional ones come with a lifetime guarantee and have a good reputation.
Wouldn't bother with the grinder station. A bench sander is a better bet IMO, but angle grinder with flap disk works for most stuff perfectly well. Same with the pipe-bender, won't use it very often for the money.
Dremel and Drill press all come in fairly frequently, dremel is the better 'gift' item.
Anonymous
hughpinder
posted on 3/11/08 at 09:31 AM Reply With Quote
Cleco /Cleko/Kleko or however its spelt - those things you use to hold panels in place (they go through the rivet holes).
Cheap multimeter for your electrics?
Hugh
m8kwr
i read that you are able to sharpen your lawn mowers blade (so another use), so i take it from that you would be able to shape metal to make sure that the joints are nice and neat before you weld them together?
iank
posted on 3/11/08 at 09:32 AM Reply With Quote
Vernier Caliper, and I agree - digital ones are easier to use but have the battery problem.
http://www.machinemart.co.uk/shop/search/filter/vernier/page/1
Anonymous
iank
posted on 3/11/08 at 09:36 AM Reply With Quote
Most people use an angle grinder for that job, much easier to bring the tool to the tube than the tube to the bench. Bench sander with emery cloth belts is a less aggressive way to tidying metal and does as good a job just a few seconds slower.
I've used my bench grinder twice, and then only for the sanding belt side. (have something like this - http://www.machinemart.co.uk/shop/product/details/cbg6sb-6in-bench-grinder-with-sander/path/bench-grinders-grinding-wheels)
[Edited on 3/11/08 by iank]
Anonymous
maartenromijn
posted on 3/11/08 at 09:39 AM Reply With Quote
And THIS for the jobs which you do at the bench.
Iamk, thanks.
EDIT: Ahh, it was already there...
[Edited on 3/11/08 by maartenromijn]
maartenromijn
posted on 3/11/08 at 09:44 AM Reply With Quote
And since I use as much scrap as possible, I often wish for a plasma cutter (not locost...)
vinnievector
posted on 3/11/08 at 09:55 AM Reply With Quote
prezzys
Ask your fam or friends when there at a flea or car boot look for a tool stall they always have selection boxes of nuts bolts and washers good stockin filler and dead handy to have around ,i also found partion tray to keep your nuts bolts washers in useful,compressor is handy
Toprivetguns
posted on 3/11/08 at 10:04 AM Reply With Quote
You cant beat airtools. 90 degree cutter with a sanding and barrel attachment.
Only drive as fast as your angel can fly... !
Paul TigerB6
posted on 3/11/08 at 10:07 AM Reply With Quote
I couldnt build a car without a radio in the garage!!!
posted on 3/11/08 at 10:32 AM Reply With Quote
Vice (and a big selection of hammers to go with it )
Dremel clone
Nice selection of files and rasps
Pillar drill- only just recently got mine but v useful...
For my last bday I got a couple of cheap angry grinders off my bro- good plan. They tend to die in a rather sudden way (ie no warning) then the rest of the days work is knackered. Keeping a spare grinder isn't that much of a luxury. You can also have one cutting, one grinding..... (ie no disc swapping)l
posted on 3/11/08 at 10:53 AM Reply With Quote
I would not be without my drill press (and vice). Soooo much better and easier than a hand drill, use it all the time for other DIY jobs since finishing the car too.
http://www.machinemart.co.uk/shop/product/details/cdp10b-drill-press/p ath/
Fred W B
posted on 3/11/08 at 11:24 AM Reply With Quote
One relatively cheap tool that is very handy is a proper electricians wire stripper.
Also the proper rachet connecter crimper.
Fred W B
[Edited on 3/11/08 by Fred W B]
Flamez
posted on 3/11/08 at 12:11 PM Reply With Quote
80mm hole cutter
Rob WM
posted on 3/11/08 at 12:13 PM Reply With Quote
I have found a vice essential.
I would second the racket spanner set as I use this every day in the garage.
A multimeter is essential for wiring.
A good drill set.
A pop rivit tool hand held (lazy tongue is good for body panels but won't fit in those awkward places)and I would also recomend a hand held rivnut tool.
Vindi_andy
posted on 5/11/08 at 02:32 PM Reply With Quote
agree with the above
Vice.
Drill press
Decent socket and Spanners ( personal weapon of choice here is the clarkes Pro range also have lifetime guarantee and (snap-on ratchet lifetime no quibble warranty use and abuse get repaired no questions asked but you pay for it))
