Pocket Dyno
nicksuper6 - 14/6/09 at 03:29 PM
Any one got this on their iphone.Had it on for over a year now and not tried it out.It is meant to measure 0-60 bhp and loads more.You have to load a bit of info in phone first like cars weight etc,to get best results.And the iphone must b steady and fixed down.That might be a bit tricky.Any way will try it out soon and share results. http://www.pocketdyno.com/
nick
Daimo_45 - 14/6/09 at 03:39 PM
Results
Not too bad for a $12.99 application.
BenB - 14/6/09 at 03:56 PM
Presumably that's just someone who's copied Dynolicious?
BenB - 14/6/09 at 03:57 PM
Originally posted by Daimo_45
Results
Yes but that's their own testing!!! What you will actually get in real life may well be different....
nicksuper6 - 14/6/09 at 04:19 PM
Done some searching and have seen test results compared to rolling road,closser than you think
iank - 14/6/09 at 05:38 PM
With inbuilt GPS and a reasonably accurate timer it's not rocket science to produce something that can do that.
gingerprince - 14/6/09 at 05:45 PM
The actual figures may not be 100% accurate (then again, are rolling roads, there's that much variation!) but it's very useful for like-for-like comparisons when making modifications. e.g. put a chav exhaust on and see how much power you lose.
Antnicuk - 14/6/09 at 05:53 PM
i bought dynolicious for my i phone ages ago but havent used it. I have much better things to think about than trying to set it up when i'm on the track... its supposed to be very accurate
nicksuper6 - 14/6/09 at 06:03 PM
Will post results when i get a few runs in.Must remember to take to Newlands Corner on next run to get results from other cars
afj - 14/6/09 at 06:16 PM
just downloaded the free version on the app store on my touch got 5.5 sec 0-60 and 13.9 1/4mile BUT says ive got 36 bhp
iank - 14/6/09 at 06:40 PM
Does it want the car weight in kg or lbs? That could be a factor of 2.2 to start off with
nicksuper6 - 15/6/09 at 06:41 PM
weight is in kgs u must also add your own weight.Dont b shy and tell the truth
