just had to drive up the road in the wet, after shed been sitting for a while, drove for about 5 mins then as i was slowing up to a roundabout she cut out. restarted her and she was fine for the rest of the trip (giving wheelspin up a hill in 3rd and 4th ) what would cause that? could it just be water in the filters? i had been following a car down the road...
Water in the tank??
Did it fire up as normal, or after a few turns of the crank?
it started as usual, and it was driving smoothly too... there was no stutter or anything before it cut out either
loose terminal then?? sounds suspect.
