I've killed it and summer fun is over :(
Werner Van Loock - 27/6/10 at 12:40 PM
I knew it was a weak point that morris minor rear axle (with a 4age in front of it), but today it gave i think. Was doing 80 and suddenly a whining noise that got stronger and stronger and only went away when i got off the throttle. It's even whining at 30 now and so loud that i can't hear the engine/exhaust anymore.
Luckily i got home
So i guess summer fun is over, got a english axle lying around but it needs brackets and a rebuild so that's not going to be under there in a few weeks
At least swimbo told me to fix it rather to sell it
speedyxjs - 27/6/10 at 12:46 PM
Could you not find another to drop in for now?
mangogrooveworkshop - 27/6/10 at 12:47 PM
WTH Do you have to ask to do stuff ?......
Get a spine boy...shes yer wife not your mother..
An axle that old is bound to give up at almost three to four times its design limit.
Mark Allanson - 27/6/10 at 12:54 PM
Get yourself a Capri axle, much more available ans SO strong
mediabloke - 27/6/10 at 01:02 PM
Only if you want it to be. Get it sorted out - you're a Locostbuilder, man!
Sure that some knowledgeable types will be along shortly with more suggestions.
[Edit: The power of LCB! There you go:]
Originally posted by Mark Allanson
Get yourself a Capri axle, much more available and SO strong
caber - 27/6/10 at 01:28 PM
Mango, I have a capri axle that I would swap for folding money and I am just over the river from you!
Caber
tegwin - 27/6/10 at 02:11 PM
I have a spare diff in the garage that I think would fit the morris axle.... any use to you?
Werner Van Loock - 27/6/10 at 04:01 PM
Capri axle under a Striker? Must be a baby atlas then, bit out of budget i guess.
And break it again? 4age is just too strong for the morris axle.
Could help, but for how long? This one only lasted 800 miles
speedyxjs - 27/6/10 at 05:46 PM
800 miles should get you through the summer. Then upgrade over the winter when the car isnt used?
Werner Van Loock - 27/6/10 at 06:03 PM
lol, you expect a short summer then
Well, i was planning to replace it anyway, so now it's a bit earlier then expected. At least i can sort the car out completely then. So in a few weeks it'll see a full cage fitted, throttle bodies, english rear axle, electronic speedo pickup and brakes sorted (not too impressed with them atm)
but thanks for the encouragement
Canada EH! - 27/6/10 at 08:18 PM
My volvo powered Sprite would eat two or three diffs a year, easy to change, but probably harder to find at a breakers than in the 60's.
