Funny handling
Alan M - 9/8/11 at 04:44 PM
My car suddenly feels like it is steering from the rear!
Does anyone have any ideas where to look; wheels and all front suspension appear tight. I am currently running loads of negative camber on the front, could this be the cause?
David Jenkins - 9/8/11 at 04:49 PM
Tyre pressure(s) low at the rear?
Suspension coming undone at the rear?
Alan M - 9/8/11 at 05:08 PM
I'll check pressures and rear suspension tomorrow, thanks for the thoughts
big_wasa - 9/8/11 at 05:19 PM
check the chassis brackets for the trailing arms and the arms at the bushes.
austin man - 9/8/11 at 05:25 PM
play in the wheel bearings ?
Alan M - 9/8/11 at 05:56 PM
Thanks for the ideas, I'll check them out tomorrow and update the post
SeanStone - 9/8/11 at 06:46 PM
Check your bushes. My car was doing that then the lower joint ended up being on the floor...Not safe!
Alan M - 12/8/11 at 08:36 AM
Thanks for the advice everone. It was excess play in n/s/f wheel bearing, following my suspension upright change. I obviously hadn't seated the inner race on the shaft properly. (Easy and cheap fix)
