As i'm not sure if my Pinto head has been converted to unleade it looks like I am goign to need to use an additivie to be on the safe side. Any
reccomendations on best/cheapest to use?
Dave
Millers is what I've used in my 2.1 Pinto since leaded fuel became unavailable.
I use Millers CVL in the single seater engine (pinto). This is supposed to be the pukka one but it is £8 a bottle and this only stretches to 20l :O
I understand Miller VSP is cheaper alternative if its not going to be under sustained high-load. Not sure on other brands.
I've used Millers VSP in my Kent engine for 7 years and had no problems; only road use though.
Why not check on the exhaust manifold side of the head to the rear of the number 4 spark plug for any stamped letters. These would be P, PP, R, RR, or
L for an unleaded head. In addition any injection head with the egg/ cam lobe shaped inlet ports will be unleaded.
[img]
unleaded2.0
[/img]
[Edited on 8/11/13 by Dusty]
