A friend has got a Grinnal Scorpion and he gave me a tip on how not to lose your cap.
Use a length of string (about 2 foot) and tie one end to the back of your cap and the other end to your roll bar, even if your cap should blow off at
least it won't go far and you can easily retrieve it.
Knowing me, I'd forget about the string and get out of the car... probably break my neck!
Use a length of string (about 2 foot) and tie one end to the back of your cap and the other end to your roll bar, even if your cap should blow off at least it won't go far and you can easily retrieve it.
Shandy drinkers the lot of ya..... I use one of these.
I think billy uses one of these
Then again I do smell wood burning every now and then...
G
[Edited on 4/7/05 by Mr G]
Or just tie a string over the cap and under the chin - very fetching...
...alternatively, you could use a length of pink ribbon (if you're feeling gay.)
DJ
[Edited on 5/7/05 by David Jenkins]
