hi,
i have a zx9r engined vortx. i have a 3.92 open diff and 195 tyres on 15 rims. when i give the car some stick i end up having to wind on a load of
opposite lock as i feel as one of the driven wheels is just not getting enough grip.
what should i do (apart from less throttle!)
lsd diff?
any suggestions very welcome as i would like to give the car full throttle and stay relatively straight. its frustrating not been able to use the
power available.
james
maybe you could look at your suspension set up ? soften the rear a little, what trye pressures you running ?
I ran an open diff on the isonblade with no probs.
I've got a zx9 Indy. I went out yesterday and it spins up so easy, the only difference is that both my tyres are spinning not just one. It
still tries to go sideways so you have to be careful
[Edited on 12/1/06 by Mad Dave]
how about a course of intensive pie eating
Corner weights need set up
My R1 vortx only loses traction if you boot it hard out of side roads in 1st gear. I am running 195 50 15s at about 18psi. I have the dampers set at
1 click from zero at the back. 0 clicks makes the ride nice and soft but a bit bouncy. 1 click seems about right for road use. I do have an LSD
mind you.
Check the rear geometry as well. both Toe and camber affect oversteer.
My vortx has more grip than I have courage, certainly on public roads lined with trees, and I have ordinary road tyres fitted at the moment.
Give Marc a ring. I'm sure he'll tell you what settings work best. that or arange to go up there in it and get him to set it up. I
doub't you'll do better than that.
I have trouble getting traction, however that might be due to having no tread left and a damp road. Must invest in new tyres soon before plod
notices.
i found today in particular to be a very greasy day, i was wheelspinning all day just driving round in a rush! and that was in a 1.8 estate!
But my
locost seems to have excellent grip most days.
Fit a car engine
Originally posted by DarrenW
Fit a car engine
Eat more pie and get some weight on the rear wheels? I cant see the difference between hight torque low revs vs low torque hi revs as the gearing
will put you at the same rear wheel rpm when taking off.
Dale
Originally posted by Dale
I cant see the difference between high torque low revs vs low torque hi revs as the gearing will put you at the same rear wheel rpm when taking off.
Dale
LSD is the way to go!!!!
