I thought I'd open this thread to separate it from some poor unfortunate's accident!
So I'll start again...
Every year this forum sees all sorts of nasty accidents, so I thought I'd list a few possible reasons to help others avoid them:
1. Inappropriate wheels and/or tyres.
2. Wrong tyre pressures / suspension settings.
3. Inexperience with:
3a. RWD cars.
3b. Very high power-to-weight ratios.
3c. Seven-style handling (i.e. their tendency to bite if abused)
4. Over-exuberance.
5. Recklessness/Stupidity.
6. Bad decisions made in poor driving conditions.
7. Mechanical defects, which are more likely in a home-built car.
8. Outside influences - other drivers, diesel spills, etc.
9. Sheer bad luck.
In most accidents I've seen reported here, a selection of these factors played some part in the accident.
Agreed!
But having a mate with a tow-truck and winch is certainly a necessity if owning a seven!
I would urge people to go to 'tracks' to push the car - at Bedford the worst thing that can happen is you fly onto some grass! On a public
road its gonna end in tears
One of the main problems with this type of car is that they are capable of much higher speed than it is possible to use safely on the public roads.
I for one, rarely use mine on the road now as I find it really frustrating.
The place to exploit the excellent performance and handling of our cars is on the track - whether it be on a track day, hill climb, sprint, race track
or drag strip. it's a lot more satisfying driving the car on the limit (of the car or the driver) on a track, than driving safely on a road well
within the car or drivers capabilities.
The situation is made worse by all the things mentioned by David.
Go easy (as we bikers say!)
cheers
Mark
Catastrophies are rarely caused by one big thing, its a combination of minor incidents accumulating.
Example, you overcook it a bit on a bend, that in itself isnt too big a deal, the arse kicks out, you steer into your skid, crap your pants and carry
on.
Except, if theres a bit if diesel on the road, you skid some more, then you find your tyre pressures are too high, and your suspension too stiff/soft
and dance a little, overcompensate, and because you've never driven a rear wheel drive car much before you end up having a close encounter with a
tree.
Yep! That about sums it up!
Or, alternatively,
1. Match the wheels to the car.
2. Set up the car properly.
3. Work your way up to going fast, learning the way the car drives as you go.
4. Don't drive too fast on roads you don't know.
5. Think like a bike rider - watch out for dodgy road surfaces when going fast.
6. On public roads, back off if you're not sure.
7. If you want to go mental, go on a track day where it doesn't hurt so much when you fall off the black stuff.
I know I sound like a BOF, but crashing hurts! Especially when you've only just got the car on the road. And, if you're wondering, I do
tend to drive a bit faster than I should... fun, isn't it!
Example, you overcook it a bit on a bend, that in itself isnt too big a deal, the arse kicks out, you steer into your skid, crap your pants and carry on.
Except, if theres a bit if diesel on the road, you skid some more, then you find your tyre pressures are too high, and your suspension too stiff/soft and dance a little, overcompensate, and because you've never driven a rear wheel drive car much before you end up having a close encounter with a tree.
[4. Don't drive too fast on roads you don't know.
I think it was hitler that said "There are lies, damn lies and statistics." well what he actually said was probably something german.... but you get the idea.
I just wonder if those stats take into account that as a percentage the 2 miles near where you live is the most used, does that make sense?
David Jenkins - 15/5/06 at 12:49 PMIn my case, the place I'm most likely to have an accident is on the road to Paul G's (aka 907)!
Loads of twistly little roads, blind corners that change direction halfway round, and bleedin' 4x4s coming the other way!
Macbeast - 15/5/06 at 02:05 PMDon't think any of these are peculiar to Sevens: All of them (maybe except RWD ) apply to any car.
99/100 it's the nut holding the wheel that's responsible.
[Edited on 15/5/06 by Macbeast]
David Jenkins - 15/5/06 at 02:11 PMAbsolutely!
NS Dev - 15/5/06 at 02:19 PMWould add that a seven is a pretty forgiving car really as it lets go at a pretty slow speed, the tendency to "bite" is pretty low.
Cars with aerodynamic aids tend to be the nasty ones here, they give little or no warning when they let go.
As for road use, yep agreed it will be frustrating, but then a 7 is much better suited to it than many quick kit and/or other cars.
Take the Ultima for example. The demo car that we took to Le Mans last year was geared for just over 70mph in first gear and will clear that gear in under 3 secs from a standing start with remarkably little effort..................................
David Jenkins - 15/5/06 at 02:28 PMI think that the seven is a perfect car for modern day driving - great handling, loads of acceleration, really not a lot of use past 100mph (but there are few places where you can do that anyway) but bags of fun.
Mine is a motorcycle substitute, after SWMBO put her foot down (just because I had an accident - or two. ).
David Jenkins - 15/5/06 at 05:59 PMquote:
Just one comment, after a bit of thought...
Most ordinary tin-tops let you know when you're getting near the limit - squealing tyres, body roll, general out-of-shapeness. Sevens follow the other pattern "ooh, this corners well... sticks like glue on that corner,,, and another corner ... ooooOOOh sh*t!!!". Or words to that effect!
In my case, I've nearly sent mine off the road while accelerating in a straight line! Tail end started waggling, and I reckon it's only many years of practice in assorted RWD cars that let me get away with it. Made me grin a bit afterwards though! I'm sure I worried the car I was overtaking...
I know I've sounded preachy in some of my previous comments, but I really hate to hear stories of new seven owners who've visited the scenery before they've learnt to drive them.
SixedUp - 15/5/06 at 06:44 PMI had a couple of scarey moments in my car when I first got on the road, and that was with a standard pinto with only about 100bhp. As I learned the car, and how to drive it, I improved, and things got a lot better.
Then, after a few years I added another 50bhp to the mix, and despite being a pretty easy-going driver, had a complete "stop the heart" moment when I caught some oil on a corner. I still remember looking out the side of the car, with an arm-full of opposite lock, at the rapidly on-coming lamppost, and thinking "I'm not going to ****ing walk away from this"
Fortunately I just (and I really do mean *just*) managed to catch it in time ... but the speed that things went wrong was unbelieveable. I'm just glad no-one was coming the other way, as I didn't have anywhere to go but under them.
Since then I've done a defensive driving course, and the amount I learned about observation, and appropriate and inappropriate speed, and always maintaining an escape route was a total revelation. Highly recommended. After all, it might just save your life.
Jon Ison - 15/5/06 at 07:10 PMGot home from work today, couldn't get onto drive.........
Jaguar with no front end, peugeot side swiped two fords a bit crumpled, straight road, dry, light 40mph limit, can happen too anyone cant it ?
BKLOCO - 16/5/06 at 09:33 AMI think the thing that concerns me most is the fact that many of our younger builders have possibly never driven a rear wheel drive car. The handling characteristics are so different between FWD and RWD that you allmost need to learn to drive them all over again.
Having spent most of my "sports"driving years in RWD (Mk1 Lotus cortina, Mk2 Savage Cortina, Triumph TR4 live axle TR6 IRS etc etc.) I was suprised to find how different a clubman type car was the first time I drove one.
I guess at the end of the day it's all down to knowing your own limitations as well as those of the car.
Although I have done an advanced driving course I think I may in the future try a defensive course. The way road traffic is going it can only help keep you out of trouble.
David Jenkins - 16/5/06 at 09:36 AMWhere would you find a defensive driving course?
BKLOCO - 16/5/06 at 11:00 AMquote:
HERE
David Jenkins - 16/5/06 at 12:22 PMHmm... Ģ900 to spend 5 days in Birminham...
BKLOCO - 16/5/06 at 12:31 PMquote:
Ok OK Put like that I'll grant you it doesn't sound that attractive.
But if I could get my company to pay.......
flak monkey - 16/5/06 at 12:32 PMI think David's (not me, t'other one ) has raised some good points here. And I think I agree with everything that has been said.
You certainly wouldnt get away with some of the manouvres I have seen people do in FWD cars in a light RWD car. However there are times when RWD has its advantages.
I'm quite lucky in the fact I have had chance to drive lots of different cars over the course of my rather short (compared to some on here) driving experience. However I by no means intend to jump into a Locost and expect to be able to drive it, and will certainly be taking the first few hundred miles rather steady! Last thing i want is an argument with a ditch (more common our way) after spending 2 years building a car...
NS Dev - 16/5/06 at 11:09 PMquote:
Very true on the age/rwd thing.
I wouldn't drive anythibg else other than RWD or the rear biased 4x4 that I drive now.
I'm 28 and my brother is 24 and nearly every car that we have owned has been rwd, and considering that's certainly over 27 cars between us that's not bad going!
Exception not the norm tho!
David Jenkins - 17/5/06 at 07:35 AMI'm getting annoyed now - first my reply got messed up, then the second attempt went AWOL.
I'll try again - what I wanted to say is that RWD is my favourite configuration, but the only easily available one is the BMW and I don't want one of them (nor can I afford a decent one).
I like that way that RWD cars don't really need power-assisted steering (it's just a luxury), it's easy to make a nice gearbox, and it just feels right when driving. I hate the tendency to understeer that most FWD cars have - "going too fast into a corner? I don't think I'll bother to go round it then..."
I much prefer oversteer to understeer, even though I know it's potentially more dangerous.
russbost - 18/5/06 at 12:36 PMReading many of the posts here suggests to me that many, particularly younger drivers have little or no RWD experience. A trip or 2 to the local karting centre could save a fortune in mistakes on the road, whilst a Kart doesn't handle quite like a Seven it's not dissimilar. To improve still further go to an outdoor karting centre when it's raining - they rarely seem to fit wets & a wet track on slicks will advance your car handling skills very rapidly - or you'll want to give up entirely!!
tks - 23/5/06 at 09:33 AMRearwheel drive,
well Rear wheel drive now adays are transit vans, Mercedes Bensz (allot of them) and offcrouse the beamers.
also rc cars have RWD. (i used to play with that to!)
My expierence isnīt very much, in fact i managed to do a 180degrees on a normal city road with dads omega (2.5TD AT (kickdown).
But it wasnīt like doing it again..
in fact i only could drive home at 10mph
mum didnīt see the damage but after a short try....
anyway it was just a moment you feel king of the road..when infact you just are novice..
i knew it would spin the rearwheels but not when locking the abs that it would turn arround completely!
RWD is deff more difficult
For example in the snow!!
With your FWD car, you just loose the pedal, the grip returns and you can take the corner, spinningup the rearwheels
with rwd loosen it and then taking the corner wonīt work very well.
in fact if you have speed your back will overtake you..
TKs
[Edited on 23/5/06 by tks]
RichB - 25/5/06 at 11:52 PMMy first car was a vw beetle - if you put some weight in the front luggage are (sand bag or two) it handled really nicely. Well within reason! The most fun you can have at really slow speeds is a beetle in the snow on a deserted carpark (again with a few obvious exceptions!!!)
[Edited on 25/5/06 by RichB]
wildchild - 26/5/06 at 08:37 AMagain, I'm probably an exception rather than a rule, but I'm 24 and most of my driving has been rwd.
70,000 miles plus in a VW Type 25 Caravelle (the last rear engined ones). Sadly now sounding like the big ends are going.
My dad's had two 3-series BMW's as company cars and I've driven a fair way in both, as well as done plenty of donuts in snowy car parks. In between he had a (fwd) Saab 9-5 Aero - 250bhp through the front wheels is, erm interesting.
Uni minibuses (rwd), people carriers (fwd), and various other random cars (mostly fwd).
And eventually, I'll have a rwd seven! Till then its the gf's golf.
wanna be builder - 26/5/06 at 11:02 AMits right to say that most yoofs only get to drive FWD cars but if they are interested enough to be building a seven then they should remember to make allowences.
i worked through uni as a white van drive (i'm expecting to be flamed to death for that) and the amount of fun that you can have in an empty van on country roads in the wet or occasionly snow tought me loads about how to handle RWD!
i recomend it to all gear head kids! (plus somebody else pays for your diesel, tyres and if your a shocking driver they insuance bill!)
Browser - 30/5/06 at 02:50 AMquote:
Rich, your avatar man's got a very scary barnet, is that from an ad in your local barbers window?
My first car was a Skoda Estelle, as with the beetle great with some weight in the front and fun on wet roundabouts & snow
