Has anybody else mastered the art of clutchless gear changes
in a pinto????
I have - LOL
i spent 3 months in an LDV with no clutch cable
How do you do that when you need to stop!(Red light??))
My mate did it regularly... apparently the gearbox doesn't last long.
A company I used to work for had a fleet of diesel metrosm as pool cars. All with close to 100,000 miles on them. To speed up their replacement,
several people practiced cluchless shifts on them.
Cluchless upshifts were fairly easy. Rev the engine a bit in the lower gear, pull it into neutral, listen for the engine to drop towards the speed
needed for the new gear and let the syncro do the work. Upshifts were more tricky, needing you to pull the lever into neutral and give a heafty prod
of the throttle to get the revs higher than you needed for the lower gear. The syncro would then let the low gear engage as the engine slowed to the
right speed.
When I picked my Indy kit up the guys in unit next door were just going out in their Transit that they had been driving for ages with no clutch
cable.
Steve.
It will be easy.......I have bought a trickshifter
easier on a bec than a cec
i used to do it all the time in my cortina, not because the clutch didn't work, but because my gearbox was knackered, and the car was ready for the scrapper anyway. just got lazy really
Don't think sow..
to find neutral you need to plan to shift down all the gears...
also how can you downshift a bec gearbox without clutch...
i'm able to build clutchless upshift meganisms wich cuts out the injection during half a second erso... but thinking about it it already scares
me...
Tks
In my (maybe limited) experience of doing it I have found its alot slower to clutchless shift a syncro box than using the clutch and heel and toeing
on downshift to set the revs.
Dog box is easier and if well practiced its quicker including left foot braking and clutchless downshifts.
Don't think so.
i'm able to build clutchless upshift meganisms wich cuts out the injection during half a second erso... but thinking about it it already scares me...
Tks
