my Indy that is now on the road has all new brakes on it from pads disks and calipers, when cold they all turn freely but when warm they bind a little
the wheels still turn but they are a little stiff, and you can feel it when slowing down, what do you think? let them wair down take them out and take
some material off ? ideas please.
[Edited on 1/5/07 by graememk]
gut feeling wear them down.
a good blat should sort them out and the sun is out for it.
my Boss has just said I can finish early ( flexi time ) and get some miles in.
regards
agriv8
We had a similar problem when our rears were new - the pistons were not going into the caliper enough (at first) the disc's got hot quickly until
the pad material had been removed... personally rather than remove pad material, I'd let them bind a bit longer as they will be bedded in.
Otherwise you'll be removing material, then bedding them in more...
thats what i was going to do, but i wanted other peoples views first
many thanks
Originally posted by graememk
my Indy that is now on the road has all new brakes on it from pads disks and calipers, when cold they all turn freely but when warm they bind a little the wheels still turn but they are a little stiff, and you can feel it when slowing down, what do you think? let them wair down take them out and take some material off ? ideas please.
Could be the master cylinder push rod has no slack. To check just crack open a bleed nipple when the brakes are binding, if that releases the brake the master cylinder is holding pressure .
