0-100
TangoMan - 7/8/07 at 06:07 PM
I did a 0-100 acceleration test at the weekend to see how close recently quoted figures are.
I could improve on the pull off time a bit as this was pulling out so had some steering to do. I didn't get a lot of wheel spin so could let it have some more as I am still getting used to the grip from the Yoho's.
I need to up the rev limiter as I ended up bouncing of it to get to 100 in third. another couple of hundred rpm (which is not a problem!!) would shave some time off at the end.
The video can be seen >here< although there is no sound as my cam appears to have thrown wobbly!!
I will try again another time to see what savings can be made.
This was obviously performed on a private road
TangoMan - 7/8/07 at 06:23 PM
Power at Flywheel (BHP) : 185
Weight without Driver (KG) : 675
Power to Weight Ratio (BHP Per Ton) : 278.47
0 - 60 (Secs) : 4.29
0 - 100 (Secs) : 11.16
60 - 100 (Secs) : 6.87
Quarter Mile (Secs) : 12.70
I reckon I could shave a second off with better pull away and higher rev limit but 11 seconds sounds bloody quick!!!
I need to do a few practice runs before the next time.
Maybe downhill
NS Dev - 7/8/07 at 06:30 PM
Ahhh, certainly sounds good, and looks good for my attempt to get under 12 secs qtr mile and under 4 secs to 60.
204hp and 560kg should hopefully do that!
Shame my mate at Ultima has been consistently running under HALF that to 100, currently pretty consistent at 5.1-5.2 secs
cadebytiger - 7/8/07 at 09:13 PM
good god Nat that is mad! what it him at the kitcar meet in the ultima?
I missed the last one but am going to try and get to the next!
See you soon i hope
NS Dev - 7/8/07 at 09:33 PM
No, don't think he's been to one of the meets yet.
I will get him to bring the demo car to one asap!!
It was the factory open day this weekend just gone.
ReMan - 7/8/07 at 09:38 PM
No it was'nt :-)
That was a 400hp "shopping" version I believe
Dangle_kt - 7/8/07 at 10:37 PM
looks like you spent about 2 second boucning around the rev limiter, and turning out of a side road can't lend itself to maximum acceleration very well (esp in a rear wheel drive )
From the looks of the speedoyou low end acceleration is blistering!!!
TangoMan - 9/8/07 at 10:25 AM
Yes, I I used to have the limiter set at 7200 until I left a piston in France.
I will give it another try with the limiter raised and on a nice straight/flat piece of tarmac.
It is quick but I expected to reach 100 quicker. Maybe I will have to take the screen off
