Not the usual request for an sva map
Wondered if anyone had a map for a 2002/3 R1 that had been optimised for a foam sausage filter at low revs.
Most of the bike maps only cover a can change and although mine is quite useable I think it could be smoother and a bit more responsive at low revs so
wondered if anyone had at low rev optimised map they could let me try.
Thanks Greg
Obviously a rolling road set up is the best way but an R1 with a foam filter is a pretty common BEC set up just thought someone might have something
to try.
Do not want to go to a rolling road yet as may change to a quieter can.
