live axle bec's
daniel mason - 2/2/13 at 09:56 PM
how do the live axle ratios effect bec performance? been reading up but cant find much about gearing. especially regarding the striker,fury and phoenix! cheers
bigfoot4616 - 2/2/13 at 10:18 PM
my 3.54 is about right for the 5vy r1 engine and was also right for the carbed blade engine. not sure about the newer blades but from when i looked into it the busa or zx10 are no good with a live axle.
watsonpj - 2/2/13 at 10:28 PM
My furys on a 3.54 diff and is ok but it previously on 3.89 and was way to revvy on a run
TimC - 2/2/13 at 10:38 PM
As above - Carb'd Blades and R1s are about all you can use with a 3.54 ratio.
daniel mason - 2/2/13 at 10:48 PM
is it possible to fit a higher geared ratio to a live axle diff? around 3.3;1 or 3.2;1
tony.g - 2/2/13 at 11:04 PM
I run a Triumph Dolomite 1850 auto axle in my carbed blade which i think is good and is 3.27:1.
daniel mason - 2/2/13 at 11:08 PM
do you run the complete back axle or just the diff and modded halfshafts? im lookin at an lsd if possible? cheers guys
tony.g - 2/2/13 at 11:10 PM
Complete axle.
Not sure you'll get a lsd easilly.
daniel mason - 2/2/13 at 11:16 PM
no.but a fair amount of the ford axles have lsds in the kits. was wondering if a different ratio could be fiotted to the ford axle?
watsonpj - 2/2/13 at 11:35 PM
The ital axle was fitted in the caterham for a while that was available as a 3.27 and you can also get a lsd i believe.
mark chandler - 2/2/13 at 11:43 PM
You need to hunt down a Capri axle, 3ltr has a nice low ratio, 2.8i special (the later ones) had LSD although both a bit rare now and a couple of inches wider than an escort.
Proby - 3/2/13 at 10:06 AM
I also run a 3.54 in my F27, with a carbed blade. Would be nice to have a bit more top end, as I'm maxed out at 120ish.
ceebmoj - 4/2/13 at 09:04 PM
If its the Atlas axle you are talking about its also a lot heaver than the English axle. I'm not sure what ratio is in my atlas but I would like something a bit longer. I have been thinking about dedion and a free lander diffs and sera shafts, as I would also like a wider rear tack.
Does any one know how wide the Ford Sierra rear track is?
