Compression Tester.....
Hellfire - 14/9/13 at 06:26 PM
Struggling to get hold of a compression tester and don't really want to buy one.
Is there anybody local (ish) who has a compression tester and would be willing to lend it out for a day or so?
Phil
JC - 14/9/13 at 06:33 PM
I've got one somewhere, ln5 0nj if that's close enough! Might be at Blyton next week.
Nickp - 14/9/13 at 07:02 PM
Got one in Wombwell if that's any use?
Shandylegs - 14/9/13 at 07:14 PM
Phil
I have one you can borrow. Barnsley based but am over in Rotherham area tomorrow.
If it's any use drop me a PM.
Thanks......
stevio73 - 14/9/13 at 07:38 PM
I'm in Selby, you can borrow mine if you like. It is old but bullet proof!
Hellfire - 14/9/13 at 07:54 PM
Originally posted by Shandylegs
Phil
Thanks......
Just checking but will it fit a motorbike engine? M10 x 1.0
Phil
Shandylegs - 14/9/13 at 09:12 PM
Phil - Yes I have both fitments.
Hellfire - 15/9/13 at 07:03 AM
Thanks for all the offers guys, much appreciated.
Shandylegs, you have U2U......
Phil
Hellfire - 15/9/13 at 12:05 PM
Nickp, you have U2U
Phil
Hellfire - 19/9/13 at 07:41 PM
Still looking for a compression tester that has a fitting with screw in thread of M10 x 1.0
A few people have the 14mm & 18mm but not the 10mm....
Anyone??......
Phil
Volvorsport - 19/9/13 at 08:01 PM
Ill have a look at weekend .. i dont think it has tho...
40inches - 20/9/13 at 08:01 AM
I have an adaptor I made from a 10mm plug, it extends the adaptor 170mm. You are welcome to borrow it.
Hellfire - 21/9/13 at 06:35 PM
Is it a 14mm - 10mm adapter? If so, could you U2U me your address and I'll arrange a suitable time to collect.
Phil
40inches - 21/9/13 at 08:02 PM
Phil
Yes, as photo. It's a 10mm plug and !8mm adaptor joined with a length of tubing araldited together. I have used it twice with no problem. Just needs tightening finger tight.
matt_gsxr - 21/9/13 at 08:37 PM
I think I used an adapter from a colortune kit. Not 100% sure.
It wasn't expensive (not worth posting around).
britishtrident - 21/9/13 at 08:57 PM
I discovered because of the larger volume before the one way valve a long adaptor gives lower readings, ie the adaptor volume lowers the compression ratio.
40inches - 21/9/13 at 10:23 PM
This is true bt, but I found it OK for comparative readings.
Volvorsport - 21/9/13 at 10:44 PM
nah , no 10mm adaptor unfortunately...
SausageArm - 21/9/13 at 11:21 PM
Screwfix sell them for 20 quid, with 3 or 4 different adaptors, i've used it on my ZX10R engine a few times.
britishtrident - 22/9/13 at 07:40 AM
Yest the aren't expensive ISTR mine was under £10 but only 14mm & 18mm and that was about 4 years ago but allowing VAT increase and inflation since then £20 on eBay should still get a decent one with a selection adaptors.
