Ok lads I think I've just about milked the humour to the limits. Just so that you know my sides are still hurting from all the humour of the past
2 days.
First of all I would like to say a very big thank you to the King of the Ali Meister's TrevD.
THANK YOU TREV.
Now I must warn you, IF you are of a sensitive or nervous disposition the following four photo's might be offensive, These photos should only be
looked at in a darkened room with adult supervision.
Fuel Tank pornography 1
Fuel Tank pornography 2
Fuel Tank pornography 3
Fuel Tank pornography 4
So I now suggest that you go and have a stiff drink after that lot.
This is what it looked like on the initial trail fit. Perfection its self.
First trial fit. Perfection.
and the reason for those notches in the back
Drivers side
Drivers side of fuel tank
and passenger side
nearside of fuel tank
Now other progress is that I think I might have a slight problem with a blowing exhaust.
possible exhaust blow ?
and this is what I have got so far on the front, currently I am waiting for some little adaptors to be made so that I can mount the indicators in the
ends of the tube. (oh and the boxes are only there to protect the carbon fibre finish lamp units)
nearside indicator extension bar
and full width (you can just make it out its a bit dark)
Full width indicator extensions
My thinking is that doing it like this should mean that mr SVA would be unable to bring all the suspension bits into the nut cover/sharp edge test
area.
Oh and the fuel tank does work out at a capacity of 11.82 gallons. I just have to pressure test it for leaks, although I am certain that I will find
none, fit the fuel sender properly get some tank straps (Thank you in anticipation Dave Meister) connect up the hoses and then finish of the rear end.
So progress is getting there. Oh and if any of you out there with a viento want or need a fuel tank then I'm sure that TrevD could be persuaded
to make another one from time to time.
As always your comments are very welcome
Enjoy.
JGG
It does seem a shame to get rid of the green fuel tank, i quite like that one
Wow
My tank is a piddly little 6 gallons and as such at approx 25 miles to the gallon, I've run out of petrol twice in 1300 miles. Can these guys
make a customised bigger tank for me??
Hi Clive glad it fits ok. Looks good in the car hope all is ok with the pressure test if any problems just pop it over and its fixed. ATB Trev.
Nice!
Nice nearly as good as mine Well done trev!
I hate to admit it but I've just been out for my first dive of 2008 and came home on the end of a tow rope
But I'm not telling what broke
Does one of those pics show some drool on top of the tank?
Yeah, not bad!
Simon
Nice tank, Nearly as good as mine now ;-)
Dave
Hope your failure wasn't tank related.
Paul
Originally posted by Doofus
Dave
Paul
Gearbox?
Dave
Paul
Nope my tanks fine half full of fuel and no leaks
But the failures a little more serious its not looking good for Stoneleigh
I agree, nice tank, but personally I would not want to be sat in the car if it had one up the rear. Just a thought from one who as had there fair share of spills.
