Hi everyone
I'm looking to use a seicento rack on a single seat midi I plan on building in the near future. Would anyone happen to know the distance between
the centres of the mounting holes?
If anyone could tell me I'd be very grateful
Paddy
You could try here
http://www.clubcento.co.uk/
Found them useful when we had a Seicento.
You may have to register to ask questions on the forum
[Edited on 24/3/14 by wicket]
If answer doesn't turn up quickly we have the factory work s manual at home somewhere and I could look up spec
atb
Mike
Cheers for that, I'll take a look
If I don't have much luck, I might take you up on that offer mike
Paddy
I am using a fiat cinquecento on my gravity racer if it is the same the centres of the two 12mm mountings is 240mm.
Matty
just checked the rack in my garage, pretty sure it's from a 600 but it's been a long time. 24cm as said above
EDIT: just found out it's from a Cinquecento
[Edited on 24-3-2014 by Benzine]
Thanks everyone!!!
That's a really great help, means I can finish up designing the front end of the chassis
Thanks again
Paddy
