750MC locost for sale
Disgruntled karter - 20/2/15 at 04:09 PM
750 MC Procomp Locost
Procomp Locost for sale.
Pictures in Photo archive.
Built in 2014 for 750 Locost championship but never used.
Built from full Procomp Locost kit with Procomp back axle and Diff. Procomp rad and aeroscreen.
With the exception of engine and gearbox,which where purchased from another Locoster , All parts used either brand new or professionally rebuilt.
Spec as follows:
Full Procomp suspension package.
Front Hubs fully rebuilt, Calipers rebuilt by ‘Big Red’ and polymer coated, new discs with Mintex 1133 pads. Procomp pedal box, with brake bias adjustment, new master cylinders, full stainless brake lines. 7” rear drums with brand new slave cylinders and NOS ford rear shoes.
Carburetor remanufactured by Carb services with cold start removed to 750MC regs. Full stainless/Teflon fuel lines with screw fittings(no worm drive clips!) new facet fuel pump, alloy modular high flow filter. Procomp alloy baffled tank.
Purpose built loom, LED rear lights (rear, rain and Indicator) recon alternator (with undersize pulley) and starter motor, new starter solenoid. New Light weight battery with cut of as required by regs.
Brand new Stack ST700 dash configured for Oil pressure/water Temp/Battery Voltage, with over/under limit warning. Fully adjustable sequential change lights and over rev warning. This was VERY EXPENSIVE !
Quick release steering wheel boss fitted with 300mm flat bottom suede steering wheel. Coupled to new 2.4 quick rack from Rally design. Brand new 6 point Willans harness in date until 2017. Brand new fire extinguisher in date until 2016. ‘HANS’ molded bead seat.
Diff 4.1 rebuilt by Procomp.
Wheels are professionally refurbished Ford Capri Laser alloys in gloss black fitted with brand new planed Yokohama’s
Gearbox Ford Type 2 GT box coupled to 681 series ford cross flow block bored to +40 currently running ford GT cam (NOT SKY FORD) engine lightened and balanced as per 750 MC rules, bills to prove. Engine done no more than 2 hrs running and never raced. Procomp Rad. Full silicon hose package.
Professionally made 3 piece full toneau cover.
The base kit from Procomp cost me over £6500, then I estimate I've spent another £3-4K on it finishing it. Silly money for a Locost I know but had planned that my son would drive it so it became a no expense obsession !! (even the wheel nuts are new!) if anybody want to look at the car its in Aylesbury Bucks, will be sad to see it go but no use it sitting in the garage
£5750
01296 641412graham
[Edited on 21/2/15 by Disgruntled karter]
Disgruntled karter - 13/3/15 at 07:18 PM
Bump open to ANY offers now need space and new project due soon so must go
[Edited on 13/3/15 by Disgruntled karter]
dhutch - 13/3/15 at 07:42 PM
Looks a nice car in tidy condition.
Daniel
Disgruntled karter - 25/5/15 at 10:16 AM
SOLD
