tools
JIZZSTER - 22/5/08 at 07:39 PM
Basically what do I need
Jigsaw? any recomendations?
Rivit gun?
what else.
haveing some tresels welded to support the car
locoboy - 22/5/08 at 07:49 PM
As random as it gets!
What are you planning on building...........
Garden furniture?
BBQ?
Garage?
Greenhouse?
Or a car?
If its a car then you will not have much call for a jigsaw, it will see comparitively little use compare to tools like
Spanners,
sockets
Rivet gun
Screwdrivers
Pliers
mole grips
grinder
hand files
Dremmell
hammers
cordless drill
drill bits
welder (optional depending upon build type)
tri squares
rulers
G-clamps
sharp knife
hacksaw
im sure there are some that i missed off
JIZZSTER - 22/5/08 at 07:52 PM
its a mac1 worx
matt_claydon - 22/5/08 at 08:06 PM
Some tissues?
mac1ZR - 22/5/08 at 08:17 PM
hi, a jigsaw is useful for cutting out the metalwork for the floor and sides, like you say a rivet gun is a must. apart from that its generally just spanners, sockets, screwdrivers etc
kipper - 22/5/08 at 08:22 PM
First aid kit.Gloves, goggles, kettle and tea bags.
Regards Kipper
INDY BIRD - 22/5/08 at 09:05 PM
and you forgot lots of patience,
And and email link to this site if you get stuck,
Failing that a very big hammer always does the job
But as your down the road can always borrow if i have something you need,
Sean
twybrow - 22/5/08 at 10:16 PM
I'd add a multimeter to that list!
miikae - 22/5/08 at 11:34 PM
Air compressor + air tools
Telescopic magnet for retreving those dropped washers etc
A good deburring tool
Heavy duty vice
Plus all the afore mentioned bits and pieces .
Mike
brynhamlet - 23/5/08 at 06:41 AM
small hammer and when that does'nt work, bigger hammer, and when that doesn't work sledgehammer
BenB - 23/5/08 at 07:02 AM
Minimum list I can think of:
Socket set
Spanners
Screwdrivers
Crimping tool
Wire stripping tool
Hacksaw (large)
Multimeter
Persuaders of various sizes (small hammer, rubber hammer, f'ing big hammer)
Allen key set
A nice big file (for filing glassfibre not storing paper )
£250 for the bits to make the car
Hand rivet gun
Mains powered drill
Lots of drill bits (esp those for the rivet size you are using)
Tin snips
Loads of time
Patient significant other / divorce papers
fesycresy - 23/5/08 at 09:10 AM
A rivnut tool.
I would say essential.
Some have made there own type of tool, I think I saw it on Hellfire's site ?
eznfrank - 23/5/08 at 10:15 AM
As above but I'd have struggled at various stages without an impact driver (and a big hammer to crack it with) and a tap and die set.
Oh and a wooden/rubber mallet unless someone already said that?
Edit - Oh yeah and a brake pipe flaring kit for when you drop something on the existing pipe like I've done twice now!!
[Edited on 23/5/08 by eznfrank]
JIZZSTER - 23/5/08 at 04:15 PM
thanks guys advice been invaluable
going shopping with my list
steve
steve
JIZZSTER - 25/5/08 at 09:02 AM
what are the most common sizes bought a nice teng 1/2 rachet for my satellite installation business and I only use 13mm sockets but what others do I need to get to cover me.
Peteff - 25/5/08 at 01:54 PM
10mm to 32mm is the common set and you'll use most of them on a build. Individual sockets work out expensive. You'll need a breaker bar and a Sierra drive shaft nut socket but you may be able to borrow that.
