L&G,
I wish to / ought to / have been advised to install MegaJolt on my MK+Pinto 2L and have a few questions that have probably all been asked before but
maybe it would be good to have a recap on the subject...
1. Can you buy a solder-it-yourself kit of board and components; if so, from whom?
2. My laptop is a 12 month old Dell with USB ports only (no RS232) and it runs Ubuntu. Is MJ software available for Linux+USB?
I also have an old Toshiba with Windows 3.11 and RS232; could upgrade this to W95 - is MJ software compatible with this?
3. What does one do with the now-redundant distributor, bearing in mind that its bottom end must be retained to drive the oil pump.
4. At 6000 rpm the VR signal is a 3.6 kHz square-ish wave; this is about 280 usec per tooth (10 deg), i.e. 28 usec per degree - presumably MJ has a
microcontroller and holds the advance map in EEPROM?
5. What are PIP and SAW?
6. Can MJ drive a standard Sierra rev counter?
7. Running twin SU carbs, is it better to use manifold pressure or throttle position (or both)?
Ta,
John.
everything you ever need to know about Megajolt
here
looks like their server is down at the moment though
Hi John,
1. Bill Shurvington was selling them, if you do a search you will find his name and address. I got mine from him and once the kit arrives you do need
to go to Maplins to buy some bits and pieces, cost me about £3:70
2. Sorry no idea
3. I think you can just put a blanking plate on, but I am not sure regarding the pinto.
4. Yes I believe so.
5. PIP and Saw are for Megasquirt
6. I believe so. There is a tacho drive from the megajolt unit and from the edis unit.
7. I would use TPS.
Hope that helps a little.
Regards
Bob
Thanks, Alex.
Yes, I've looked through much of that, but I was looking for answers more from an end user's point of view rather than the
manufacturer's.
John.
Autosport Labs - not sure if they do a kit any more. If they do, it's now surface-mount components, which ain't so easy!
No Linux software
This would work - I've got an old Tosh Satellite running Win2000, but I believe it works with Win95. You'll have the advantage of a proper
RS232 port on an old machine.
A Pinto owner will have to give the exact details! (ask DaveFJ, 'cos I know he's done it.
Exactly.
One's the signal from the EDIS to the MJ, and the other's the signal back - the MJ unit varys the timing between the two to control the
timing.
Not sure - but I doubt it.
Easier with a TPS (but a MAP sensor isn't impossible).
Hope that helps!
Thanks, Bob.
I've seen Bill's name mentioned and will try to contact him.
John.
John you have u2u
This how I did mine...
Cheers Rich
Many thanks, guys.
That's a really good pictorial, Rich!
John.
Here's the link for buying the kits
Kit link
I made my own after ordering it from here, not that difficult just have to know how to use a soldering iron.
OK JUST TRIED THIS --- on Ubuntu Acer Aspire One
Megajolt software loads under WINE on Linux but I think the COMMS will be the issue, Linux handles comms ports a lot different from Windows so
i'm notsure you'd get it to commuincate.
also the 3d Map bit doesn;t show up
You may also have probs as you don;t have a real rs232 port when running linux
It'd be cool if someone ported this full to linux or re-wrote in in JAVA of something.
Originally posted by mad4x4
It'd be cool if someone ported this full to linux or re-wrote in in JAVA of something.![]()
Brent Picasso has said that he will make the source code available to anyone who wants to try porting it to Linux.
You'll be better off with your laptop though - there will be times when you will want to adjust things while in your car, and you may not want to
lug your desktop out to the garage. You can also use your laptop to log data while on the move.
Kit link
If you use megsquirt and spark rather than megajolt then linux is very well supported by MegaTuneix
http://megatunix.sourceforge.net/
PIP and SAW are the EDIS connections.
For a road car or any forced induction then MAP is the right way to go if you can, TPS is good for the track but fuel consumption won't be as
good and it doesn't work on turbos/superchargers. IIRC Megajolt can only be configured for one not both.
Originally posted by iank
For a road car or any forced induction then MAP is the right way to go if you can, TPS is good for the track but fuel consumption won't be as good and it doesn't work on turbos/superchargers. IIRC Megajolt can only be configured for one not both.
Originally posted by David Jenkins
The latest version, V4, uses surface-mounted components that take a bit more skill to solder. Take a GOOD look at the assembly guide before you make up your mind
