Does anyone know the basic wiring for an ignition wiring lamp?
B
If you mean the charge warning light, it's simple. Take a wire from the ignition switch to the lamp, and from the lamp to the alternator. Just needs to be a position on the ignition switch that is live when the key is in the on position. HTH Ray
