lights instruments wiring
RK - 16/5/08 at 07:31 PM
I have ZERO knowledge of electrics (other than positive and ground/earth to you). How many hours does it take an expert to wire up from scratch, tacho, speedo, 4 other instruments, tail lights, front signals, headlights etc.? Should I buy a loom or do it individually?
I have read the info in this month's Complete Kit Car, and am no further ahead!
I am trying to budget for an expert to come and do it, because I really have no patience/knowledge of it, and I don't want my car to catch fire. The engine is already wired to the point where it starts and runs.
Griffo - 16/5/08 at 07:37 PM
probably wouldn't take very long for an expert to do it, especially if there is no ECU involved.
however, I would expect it wont be cheap.
If you do it systematically and make sure you label everything it shouldnt be to big a job (although you will need to know what pins do what).
mookaloid - 16/5/08 at 07:49 PM
Premi er Wiring are really good. Can't recommend them enough.
Mark
RK - 17/5/08 at 03:20 PM
It won't solve my problem. I will then have a loom that I don't know what to do with. They can't exactly come over to my place to help. But thank you anyways for the responses!!
[Edited on 21/5/08 by RK]
