Hi all
Recently purchased a 07 plate crv with built in sat nav to tow our caravan. However the disc is from 2007 so slightly out of date. Rang honda for an
update and they want £108 + vat! And its only upto date when you buy it.
Is there anywhere else these discs can be obtained 😜
Tried eBay with no joy or ones on there aren't much difference in price
Haven't used them, but a quick google resulted in this:
http://www.satnavdvd.co.uk/2015-honda-v390-navigation-map-sat-nav-update-disc-181-p.asp
Thanks. Looks promising. Will investigate a little further
Would be interested to know how you get on with this
Word of caution.
I have a 2007 CRV - but it is the 2005/2006 model and the new map disc does not work - tried a friends at work.
I know the description states 2007 onwards, but just make sure your CRV is the later model.
Originally posted by avagolen
Word of caution.
If you're reasonably techie and don't mind getting into "alternative" sources, there are sites like
this.
[Edited on 25/11/15 by GeoffT]
The sites selling discs for 30 quid are usually just burning pirate copies that are downloaded from the internet and making a small fortune in the process!
